can i fly over high voltage cables with dji phantom
Discussion in 'Phantom 2 Vision Discussion' started by mycargotransport, Jan 18, 2014.
  1. mycargotransport
  2. Nvr2fst
    Now every time there is a new guy I am a bit leery. Especially when one was just kicked out the side door.
    Well, here I go.......somebody throw me a lifeline..
    Your answer would be- It is a possible risk. I have but your results may vary.
    Something tells me this may be a setup.
  3. Pull_Up
    South Oxfordshire, UK
    Be interesting to see IP addresses, wouldn't it?
    Nevertheless, as has been said, received wisdom is (and DJI manual says) stay away from them. If you do go near there might be trouble, or you might be fine.
  4. Nvr2fst
    Cannot block IP?
  5. BenDronePilot
    Any web site worth it's salt should be able to track any IP's connecting to the server as well as having a handy dandy Block or ban list to keep repeat offenders away.
  6. Nvr2fst
    That is what I figured.
  7. BenDronePilot
    Don't feed the troll. Oh and yeah you can in theory fly above a high voltage cable, though it's not generally recommended.
  8. b2pilot186
    Too easy...OP is going on FOE list.
  9. BigPig
    Incoming!!!
  10. Firestat
    Columbus, Ohio USA
  11. iDrone
    Los Angeles, California USA
    1) Yes. I fly over 120' HT lines regularly w/o incident.
    Can you? Unknown, your HT lines may vary.
    Advisable? Officially not recommended.
    2) Yes. phpBB can block IP addresses, but only the Admin or one of its Mods can do so.
    iDrone (the Very)
Similar Threads - fly high voltage Forum Date
How high can this dron fly? Photos and Video Dec 16, 2017
Flying a drone in high winds is DANGEROUS Phantom 4 Pro Discussion Nov 18, 2017
Flying at a highly populated area... General Discussion Oct 21, 2017
P4 wont fly higher than 26 to 30m without losing connection Phantom 4 Help Sep 14, 2017
Flying over several hundred high school soccer tournament players? Pro/Adv Discussion Aug 6, 2017
