I don't think the specs are the same. And RF power output is usually dictated by hardware, along with the FCC filing for U.S. Operation. I'm doubtful firmware can help, but I hope I'm wrong.If the specs of the RC are the same, I would imagine that there is a firmware problem with the P4 RC firmware. I would encourage as many of you as possible to write to DJI and demand that they fix this. I can tell you that I get about 1/2 the range on my P4 as I do on my P3. Same location, environment, etc. And I had a newer P3 with a new remote.
It's the power output from the craft to the ground that matters most, not the controller. In fact I think think output from the P4 controller was boosted, but that doesn't help the video and telemetry signal from the craft. I think the craft RF power output has been compromised in the P4.I think the specs are the same between the P4 controller and the most recent P3 controller.
I own a P3A and a P4. I flew identical missions using LITCHI under no ind conditions. Flew the first mission with the P4, 8:03 minutes, returned with 62%. Flew second mission with the P3A, 7:55, returned with 64%. P4 battery was new. P3 battery had 8 flights.I had a flight of 21 minutes with 18% battery life remaining. Started off with 98% charge. Nothing fancy and definitely no sport mode. But, I bet the 28 min battery time came from a stationary flight, indoors with no wind.
I'd be willing to bet I could get 25 mins on a single battery.
I just kept flying it. It was trying to land but I kept positive stuck control until it hit 2%... Got nervous so manually landed it at that point.How do you take it to 2%. Doesn't it auto land at 10%?
I second that. And while I love the phantom 4's quality, the range is, to put it mildly, **** compared to the 3 pro advanced.I would say this gets close to fraud since DJI claims 25% better battery life on the P4 versus the P3.
The data are coming in and showing WORSE battery life (and worse distance).
The EPA analogy holds no weight because if a car company claims 25% better mileage on a new model and in usage it is actually worse- there would be a class action lawsuit.
