This stopped working a few weeks ago, then started working again. Now it won't work. I have used the DJI Assistants software and the lever on the control shows travel but the camera will not move. On start up, the camera gimbal goes through its motion and returns the the facing forward position. It will not change positions when the controller is actuated.If you use the sticks as if you are turning, the camera will move but the control switch in the back will not cause the camera to tilt to the 90 degree position. Stumped!
Phil H
Update:
I fixed it in the Assistant program by adjusting the sliders under Gimbal.
Phil H
Phil H
Update:
Phil H
