Camera with Phantom powered off
Discussion in 'Standard/4k Discussion' started by bunkphenomenon, Feb 1, 2016.
  1. bunkphenomenon
    When I have the gimbal guard off, and the P3S powered off, is it normal for the edge of the camera to touch the surface of the ground? To be more precise, when the lens is parallel to the ground surface, theres about .5" clearance, but if the camera is tilted, the right edge of the camera touches the ground (as you are facing the Phantom)
    When the P3S is powered on, the camera has plenty of clearance.
  2. 250Flyer
    United Kingdom
    Mine does not touch the ground when it's powered off or on. Try auto calibrate then power down see what that does...
    If not check the rubber dampers and drop kit that hold the gimbal plate to make sure they're not damaged.
  3. bunkphenomenon
    My phantom came with 2 drop kits installed and the other two as spare, should all 4 be installed?
  4. 250Flyer
    United Kingdom
    2 are only required.
    Just check to make sure non of the rubbers that are installed are damaged.
    bunkphenomenon likes this.
Similar Threads - Camera Phantom powered Forum Date
Phantom Camera Feed Froze and Flight Controls Became Slow to Respond General Discussion Aug 10, 2017
Phantom 3 4K Camera/Gimbal does it work on Phantom 3 Pro? Pro/Adv Discussion Aug 1, 2017
Professional Phantom 3 Pro Camera Not leveled and looking left Phantom 3 Help Jul 29, 2017
Phantom 3 Standard with no camera... is this the end!? Standard/4k Discussion Jul 28, 2017
phantom 3 advanced camera Pro/Adv Discussion Jul 24, 2017
