  1. Romenfree
    I have removed the lens from the camera only to see if it was easy enough to do before I purchased a set of filters, read a story where the lens broke when being removed.
    What I have noticed is the thread is binding and was wondering if there is something I can use to make the lens screw on and off easier without causing other issues.
  2. Dacon Productions
    Gilbert, Arizona
    Yes.
    NEVER use ANY oil based lubricants on the threads. In time the oils will evaporate and deposit a thin layer of film (oil) on the lens. What we have used in the film industry is this:
    - get a #2 pencil and a white sheet of paper
    - get a LOT of pencil lines on the paper
    - use a Q-tip (or similar) on the paper till it gets dark from the graphite
    - hold the filter DOWN and gently smear the threads with the Q-tip full of graphite
    - blow the threads with a photo blower (hand pump) but not all the graphite off
    - thread ON and OFF a few times to lube the threads
    After that the threads will be smooth.
    LosDosMonitos and Romenfree like this.
  3. Romenfree
    See, I knew I would stuff it up if I didn't ask.
    Cheers
  4. msinger
    Approved Vendor
    Harrisburg, PA (US)
    For some reason, the UV filter has a sticky feeling to it when screwing it on/off. I've never noticed this with the many filters I've tested. After you pick up some filters, you probably won't find you need to use the UV filter much.
  5. Erised
    Totally agree. Your source of graphite is smart, I wish it was my idea, good thinking.
Similar Threads - Camera thread sticky Forum Date
Professional Broken camera gimble and motor shaft thread Phantom 3 Help May 2, 2017
Standard Camera pitch issue Phantom 3 Help Yesterday at 12:14 PM
Standard Camera sensor issue Phantom 3 Help Yesterday at 11:21 AM
Camera/gimbal Replacement Phantom 4 Pro Discussion Yesterday at 1:35 AM
Lidar Cameras Construction Saturday at 10:41 AM
