Camera servo from eBay
The Emax ESo8MD servo is too big. It measures 32mm X11.5mm X 24mm. The 32mm part is too big. The Emax ESO8MAII measures 24mm X 11.5mm X 23mm, which is almost exactly the same size. Before I order one I need to find out the difference between analog and digital servos. The description makes this specification and I'm not sure which type DJI uses. Anybody know? We're getting close!
I used the ESO8MD and it fitted ok after i cut the little side tabs off it actually was a bit shorter than the original one as I had to put a small plastic wedge at the back to stop it from moving about.
