Camera ribbon protector
Discussion in 'General Discussion' started by Jay, Apr 12, 2015.
  1. Jay
    Jay
    UK
    Hi does anyone know if the camera ribbon protectors on eBay are worth getting and if so what is a good one ? Also the guard that goes on landing gear to protect the camera from knocks.
  2. msinger
    Approved Vendor
    Harrisburg, PA (US)
    You can find the most commonly used gimbal protectors here:
    DJI Phantom Accessories & Tips - Phantom Help
    The Camera Guard is built well and seems like it'll add some protection if landing onto something. I haven't had the opportunity to confirm that though. There are a lot of similar guards, but some are made of plastic and/or do not appear to be made as well.
    For gimbal protectors, I've tried the Inertia Guard and Phantom Fix (the original version). You definitely should not buy the original Phantom fix -- since it is semi-permanently attached with double sided tape and is hand made. The Phantom Fix 2 screws on and is machined, so it has a more precise fit. If cost is important, I'd recommend the Phantom Fix 2. If you're looking for the most polished product, then I'd recommend the Gimbal Saver. Both should offer the same amount of protection since the designs are nearly identical.
    #2 msinger, Apr 12, 2015
  3. Jay
    Jay
    UK
    Thanks for your help
Similar Threads - Camera ribbon protector Forum Date
Video and Camera operate but no movement after Yaw arm and ribbon replacement Standard/4k Discussion Aug 15, 2017
Places to buy Pro/Advance camera ribbon cable part 49. Pro/Adv Discussion Jun 20, 2017
Dji GO app connect to camera with broken ribbon Pro/Adv Discussion Mar 17, 2017
Camera ribbon replacement now this! Phantom 2 Vision + Help Jan 31, 2017
Installed new ribbon, but camera not moving p3a General Discussion Jul 10, 2016
