Camera problems.
Discussion in 'Standard' started by Montana Bob, Jan 1, 2016.
  1. Montana Bob
    When drone is 200 feet away, I loose camera signal. Is camera feed coming from drone or controller? Galaxy s 5 is mounted on RC. You should be able to see what the drone is seeing half mile away shouldn't you? All firmware is updated. Please help
  2. Jay H
    Long Island, New York
    Are you losing RC signal or are you losing wifi (Low image transmission)?
    Half Mile range is under optimal conditions with little to no interference.
    Are you in beginner mode?
    Also, are you pointing the antenna correctly?
    #2 Jay H, Jan 1, 2016
  3. Montana Bob
    I think it's wifi I'm loosing. The drone flys fine at any distance but I loose my picture and info distance. On start ups I have to start everything a couple of times to get a picture, then fly it and a few hundred feet away the camera goes down and says lost signal so I fly it back and start over. I think it's a remote controller issue. Beginner mode is off and the antenna is correct. I'm lost.
Similar Threads - Camera problems Forum Date
HELP! Unusual P3A start-up problems, connects OK but camera drops forward Pro/Adv Discussion Sep 26, 2017
Standard Camera problem after gimbal repair. And other problems Phantom 3 Help Jul 24, 2017
My Phantom 4 video camera has problems. Phantom 4 Discussion Jun 4, 2017
Advanced First drone camera and gimbal problems Phantom 3 Help Jun 3, 2017
Problems with phantom 3 professional camera recording General Discussion Apr 4, 2017
