Camera Problem after the latest 3.06 update :-(
Discussion in 'Phantom 2 Vision Discussion' started by Jay, Aug 1, 2014.
  1. Jay
    Jay
    UK
    Hi all
    Just updated my dads P2V with the latest update 3.06 and now there is about 15 seconds delay between the phantom camera and his iPhone does anyone know why ? :roll:
    Just tested my p2v and was very disappointed to find that after the new update from only about 180m away the picture froze up and also at close range had probs with it now wishing I had left it alone.Wondering why this is happening as I read I'm not the only one
  2. Barandbrew
    No
    But I have the same problem so would like to see a fix a well
  3. MikeON
    Pennsylvania, USA
    What do you have your preview resolution set at?
  4. Jay
    Jay
    UK
    Tried it at 640x480 15fps and 320x240 15fps still rubbish almost unusable.Wish we had a solution to fix it
  5. J Dot
    Sarasota, FL. USA!
    Hello,
    DELETE your DJI app, reinstall DJI app, reboot smart device,
    Open app, change preview quality to 640x480 15fps, or lower!
    Give this a shot!
    Take care, Fly safe!
  6. Barandbrew
    I have deleted and reinstalled the app reset the iphone but still have the problem .
    It seems ok before the motors are started picked up the phantom and moved it about and the video seems ok but as soon as the motors start the delay comes in. Doesn't happen with my ipad ?
  7. J Dot
    Sarasota, FL. USA!
    The problem is DEFINATELY in your iPhone,
    Have you updated the phone lately ( not the app )
    But the actual phone? You might have a bad wi-fi unit in
    Your phone?
    Make sure you turn OFF airplane mode, and Bluetooth.
    You might want to turn off cellular data as well?
    I use an IPHONE 4s running 7.1.2 firmware,
    Running 640x480 15fps, with no problems, when I try
    640x480 30fps, I get delays.
    Keep us informed
    Take care, fly safe!
  8. Jay
    Jay
    UK
    Thanks will try it out later and see if it helps
  9. Jay
    Jay
    UK
    Still have delay but not as bad when preview quality is at its lowest.Wasn't like this before the update
  10. RCRookie
    East Texas
    I haven't had good preview quality since leaving Revision 1.08
    640x480 30 fps worked back then. It hasn't worked since.
  11. Jay
    Jay
    UK
    Tried them all still crap
  12. jamescstacey
    I experienced the same problem (iPhone 5 with 1.0.42) while taking still photos. The display turns black and white and freezes. I can still take shots, but have no visual. I updated to 3.06, hoping that would resolve the issue, but if anything it's worse. It seems to happen when I push the limits of the wifi range extender which for me is about 175-200ft, and it won't correct when I bring P2V back down. Forgive what might seem like a dumb question, but the orientation of the controller antenna should have no impact on my display, right?
  13. Jay
    Jay
    UK
    The controller antenna won't affect display.
Similar Threads - Camera Problem latest Forum Date
Advanced Camera problems on latest up dates Phantom 3 Help Jun 12, 2016
Professional Problem with camera gimbal Phantom 3 Help Aug 1, 2017
camera problem Pro/Adv Discussion Jul 30, 2017
Standard Camera problem after gimbal repair. And other problems Phantom 3 Help Jul 24, 2017
phantom 4 pro camera focus distance problem Phantom 4 Pro Help Jul 3, 2017
