Camera not straight after crash.
Just had a crash. Everything is ok but now the camera seems to tilt slightly to the left. I have done a gimbal calibration but still not perfect. However the system says everything is fine. Is there a way to adjust the gimbal / camera manually?
Sent from my SM-T815Y using PhantomPilots mobile app
Also hold down the C2 button on the bottom of the remote while you are flying and turn the wheel (right side) for minor adjustments for a straight horizon too.
Does it matter what C2 is programmed to do?
Have you checked the white cushions that connect the camera gimbal mount to the drone body's silver piece? Even a slight bit of one if the being cut can cause the camera to sag. I theorize that it's not good to have the camera floating, not supported. I discovered this post crash.
