camera issues
Discussion in 'Pro/Adv Discussion' started by timmeh, Mar 27, 2016.
  1. timmeh
    North Dakota (hell)
    OK so reading here I learned alot.. finally put the camera back on and the cool lens hood seems to freak it out.. it will be fine for a few min then the camera will drop to straight down then return to its original position.. I take the lense hood off and it's fine? Bad gimble? I've only had the pro 3 fora couple weeks and I didn't even use the camera until today.. other than a limp camera :D now and then it's been great.. any help is greatly appreciated TIA
  2. Meta4
    Meta4 Moderator
    Staff Member
    It sounds like you are overloading the gimbal with an unbalanced load.
  3. timmeh
    North Dakota (hell)
    So don't use the lense hood? It was made for the phantom 3.. sorta suck that it's happening.. I'm afraid if I put a filter on it will do the same
  4. exit 4
    Southern New Jersey
    The filter replaces the lens cover so the weight gain/loss is even. Find yourself a good filter set and you will be fine.
  5. Oso
    Oso
    Western US
    I agree with Meta. It sounds like whatever you put on your lens is too heavy and it loads up the front of the lens too much for the gimbal to balance. I would not recommend putting additional weight on the camera with a lens hood, but if you do it may require a counterbalance weight on the side opposite the lens depending on how much weight you are adding.
    As for filters, most don't add much incremental weight since they take the place of the original. Some filters do add weight however, so be sure to understand if the ones you are thinking about require a counter balance or not.
  6. timmeh
    North Dakota (hell)
    This is the piece.. wonder if I can lighten it
  7. alokbhargava
    San Francisco, CA
    This cover appears to be heavy. Can you weigh it?
  8. timmeh
    North Dakota (hell)
    I will try to. It's made by ultimamaxx
    #8 timmeh, Mar 28, 2016
Similar Threads - camera issues Forum Date
Camera alignment issues Standard Jan 11, 2018
App camera view issues Pro/Adv Discussion Dec 31, 2017
P3pro camera issues Pro/Adv Discussion Oct 29, 2017
Phantom 4 Camera Issues Phantom 4 Help Sep 12, 2017
Camera Issues - P3A Pro/Adv Discussion Sep 5, 2017
