Camera issue when using RAW
Discussion in 'Phantom 2 Vision Discussion' started by Outtahere100, Mar 26, 2014.
  1. Outtahere100
    Puerto Vallarta, Nayarit, Mexico
    I changed my camera setting to RAW several days ago and all seemed to work fine. Yesterday, I took off, snapped a still pic in RAW and noticed a few seconds later the the video mode was active and the video and still buttons were grayed out. This problem was repeatable. I thought the problem might be related to my having the video setting mode to start recording when control signal lost. That turned out to be the case, if I disable video start recording on control failure, the problem is gone.
    Anyone else run into this?
    Thanks!
  2. rnrnrn
    Yes, same here. I simply resolved to keep this setting in case of control signal loss off but yesterday I had to use a friend's phone and this happened again due to default settings after installation.
    You may also experience video recording starting automatically with the buttons not greyed out - then you can simply switch it off but it's still annoying it happens. only way to completely skip those issues is to disable RAW :p
    cheers!
  3. Outtahere100
    Thanks. At least it's not just me:)
  4. petersachs
    Branford, CT
    Just posted this same issue yesterday. See: viewtopic.php?f=7&t=10978
    I have not done the latest (3/26/14) firmware upgrade, so it's not a result of that. It's apparently related to the "When Connection Breaks" setting in the App's setting area. (Discussed in that thread)
Similar Threads - Camera issue using Forum Date
Camera alignment issues Standard Jan 11, 2018
Camera issue (dancing problem) Standard Jan 11, 2018
App camera view issues Pro/Adv Discussion Dec 31, 2017
Camera Issue and Recommended Settings Photos and Video Dec 21, 2017
P4 camera issue Phantom 4 Help Nov 2, 2017
