Hi, just looking for a link to a video with a guide for removing the Gimbal/Camera assembly from the PV2+
Thanks So Much!
-Chief
Thanks So Much!
-Chief
See the attached photos to remove. I would remove it from the phantom if you want to continue to at least fly it. You will have to sacrifice one disc and one pin. Extras were included with your Phantom. The REAR you will want to cut the disc, the FRONT you will want to snip off the head of the pin. This will only cost you one of each rather than two pins or two discs at once. Then carefully pull the silicone dampers off, then pull the front cables off, the side cable has a small hook that keeps it in. You need to pinch it and pull to remove.
TheChief said:Hi, just looking for a link to a video with a guide for removing the Gimbal/Camera assembly from the PV2+
Thanks So Much!
-Chief
Fred_C_Dobbs said:From the very helpful guys at Dave's Motors:
Unfortunately the photos are too large. If you PM me with your email I can forward the email I got from them with the pics.
