Camera direct to tablet?
Discussion in 'Pro/Adv Discussion' started by ScopeTech, Jan 12, 2016.
  1. ScopeTech
    Did anyone know whether the camera/gimble can be connected directly to a tablet for output? Just curious as I picked up one of these handheld gimble attachments as per the attached pic and it has a spot to mount the tablet mount, but not sure why they would bother if you can't connect it directly to the Phantom.
  2. John Locke
    Yorba Linda, CA
    So you bought that without knowing how it works, and no instructions? RTFM?
  3. With The Birds
    Australia
    You should have gone for an inspire 1 and an OSMO. That looks like a really difficult way to turn your phantom into a stabilised 4K camera and close to useless if you can't mount the remote also.
  4. ScopeTech
    Wow, aren't you quite the douche. I'm sure you make a lot of friends with that attitude.
    dirtybum likes this.
  5. ScopeTech
    Bottom line is, I bought the P3P for aerial videography purposes, saw this and thought it would be cool to turn it in to a handheld gimbal with a 40 dollar addon if possible and if not I'll send it back.
    #5 ScopeTech, Jan 12, 2016
  6. With The Birds
    Australia
    I was trying to be constructive. Without a convenient way to obtain video feed and canera control its arggably useless... you need the remote and aircraft powered for stabilisation and recording in any case. I would return it.
  7. With The Birds
    Australia
    And yes, i suspect it was advertised as the solution to turn your phantom into a stabilised 4k canera. They wouodnt have nentioned you need a two man/woman crew to operate it.
  8. ScopeTech
    Yep thanks that's pretty much my take on it, just wanted to confirm that there was indeed no direct connection available between the camera and a tablet.
  9. With The Birds
    Australia
    There are opportunists about. A lot wouldnt bother to return it so a nice profit.
  10. ScopeTech
    Someone else on the forums was kind enough to post an example of something very similar except it has a hook to hang the remote on, makes perfect sense to me and easy enough to modify this one the same way; what will that get me? That's right - a handheld gimballed 4K camera for 30 bucks over the cost of the Phantom 3.
Similar Threads - Camera direct tablet Forum Date
Litchi, need help w/ Direction of camera Control (Go, Litchi, etc..) Jul 24, 2017
Standard waypoints and camera direction question Phantom 3 Help Mar 3, 2017
camera points wrong direction Standard Feb 19, 2017
Professional $389 pro 4K Camera direct from DJI Phantom 3 Help Mar 11, 2016
Camera direction Standard Dec 27, 2015
