camera connection fails when engines engage
Discussion in 'Phantom 2 Vision + Help' started by croaker, Aug 24, 2014.
  1. croaker
    out the box P2V+, everything working great flight-wise, and set-up. Video feed comes up on app (iPhone 5c), however every time I engage the engines, image goes grey, freezes and "connection the phantom failed" message appears. wifi still connected, had lots of great flights, but no app connection in flight.
    called Austin service desk and advised to re-bund. I did that and had video connection very briefly with engines on, but never more than a few seconds. before engines started, I can take pictures and video from app. Any suggestions appreciated!
    Puzzled in New Orleans
  2. harbourside
    What preview quality are you using ? Try it at the recommended default of 320x240 15fps.
    Also, are you running the latest firmware for all devices ?
  3. croaker
    Harbourside, Thanks for the suggestions! I have not changed any preview settings, but will investigate. I can't find them on the app "settings". Where are these located? (very new to this). I will also read up on syncing the firm-ware. I tried yesterday, down-loaded the dji software and it looks like everything is up to date. love this forum!
  4. harbourside
    Preview quality is set in the camera settings page on the app, but if you have not played with it then it will be set at default.
    I have not had any trouble with my phone (android) but I have seen people struggle with connection if they are not running all the latest firmware.
    You need - PT2 3.2 Assistant for the Phantom which will give you 3.06 firmware, RC assistant for the transmitter, 1.52g for the camera and the DJI app should be 1.0.52.
    If you connect the phone to the Phantom you can check what versions are installed by going to settings / about, that will list them.
  5. croaker
    NAZA-M is 3.04, APP 1.0.42 1.2.5g camera
    I'll upgrade and report back. Thanks!!!
Similar Threads - camera connection fails Forum Date
Connection fails after binding to camera. Phantom 2 Vision Help Jan 13, 2017
Firmware/Software/IOS 11? No camera view or connection Pro/Adv Discussion Oct 22, 2017
Replaced Camera & Flew Once, Now Connection Failed Phantom 2 Vision + Help May 30, 2017
Lost connection to the camera Phantom 2 Vision + Discussion Feb 19, 2017
2.4 Ghz wifi connection if camera is removed? General Discussion Feb 17, 2017
