Camera Bracket Breaks Easily
I can't believe how easy these brackets break. I have now figured out to barely tighten the screws and leave a gap between the bracket and mount.
Weird... I've never had an issue... But I don't mess with it much... Do you take your camera on and off a lot?
Yes I do. I use my camera for skiing, biking, swimming, etc.
I don't even use that on mine, I just use a hair tie to hold mine on, works great and the camera is much easier to remove when I want to.
Ahh that explains it then... How long did it last before it broke?
dptcalvin said:
http://www.shapeways.com/model/2224302/gopro-zenmuse-bracket-h3-3d.html
Problem solved.
+1 Best invention evah!
Rubber band works, but this does the job and looks the goods.
The original H3-3d hex screws were atrocious to remove.
alanw2005 said:
You use one of these???
http://en.wikipedia.org/wiki/Hair_tie#m ... r_ties.jpg
Yep that's basically what I use, cheap and works really well. I have a lot of them on hand because I have long hair. I went that route because like everyone mentioned, the screws on the bracket are a pain in the butt to remove. If you have a wife/girl friend chances are you could get one from them.
Problem solved.
Got one if someone wants to buy it? I used it 2 flights. NEVER had an issue with the gimbal, put this 3d printed part on - Bird was sitting on my table turned it on and the gimbal started tweaking out making a bunch of noise. Took it off and not a problem since.
So, instead I super glued my broken one, didn't tighten is so much, good ever since.
alanw2005 said:
Problem solved.
Some people have had issues with the shapeway bracket:
http://youtu.be/Q4QpNZnAVIg
Some people have problem with everything they buy. So if it doesn't work send it back for a refund.
cokersean20
