OK I'm getting several different answers to this issue/question/symptom??? I bought the new upgraded V3 Transmitter for the P2V+. I thought everything was working the way it should with the function of the camera angle wheel/dial. I even had a Brilliant DJI Tech guy tell me that it was operating the way it should. Then I chatted with a buddy from Canada who just upgraded his & I was explaining my complaint with the new TX. He tells me that his operates EXACTLY the way I want mine to operate!!! So now it's a freaking Controversial!!!!
My dial does the following when in use...I have to keep my finger on the dial to position the camera in the direction I want. The center static position of the camera when I let the wheel/knob go is in an approximate 35 degree angle? Now if I move the wheel up fast-then it will respond fast. If I turn the wheel slow-then it will respond slowly. BUT IF I LET THE WHEEL GO IT GOES TO THAT 35 DEGREE POSITION, unless I put some pressure on the wheel & move it back to where it would be sitting with the old TX????
Now Canada tells me that his camera will go the the old P2V+ TX resting angle when his wheel/knob has no pressure on it, (so pointing straight forward I guess...) And when he points it to a new position say 42 degree-then let go of the wheel-the camera stays in the 42 degree pos? That goes for any new position of camera angle he puts it in. So could some of you guys tell me what your "KNOB" is doing????!!!??? What that sounds weird!!! LOL Can you guys tell me what your wheel does??? I'm confused. I am really trying to get all my stuff dialed in perfect for a Colorado trip I am going on strickly for my Drone!
Thanks...
Moose
Thanks...
Moose
