The P3P had a 4 K camera-- 2.7 K is more that you need unless you are a professional photographer and need 4K output.Does the p3a take the same quality pictures as the p3p even on the new update allowing 2.7k on p3a? Or is it just the video quality alone is upgraded basically?
The 2.7k is good I just want to know do you get the same quality pictures using both p3 modelsThe P3P had a 4 K camera-- 2.7 K is more that you need unless you are a professional photographer and need 4K output.
I guess it depends on the expertise of the Photographer, but I would assume that 4K would produce better quality than 2.7 K although I don't know that to be a fact.The 2.7k is good I just want to know do you get the same quality pictures using both p3 models
yes exactly the same. 12megapixel sensors both shoot DNG and JPEG. I would also suggest downloading DNG converter from Dji website to process your stills before you retouch them. cheers!Does the p3a take the same quality pictures as the p3p even on the new update allowing 2.7k on p3a? Or is it just the video quality alone is upgraded basically?
Yes it's about the still photos... Do they take out the same quality pictures?4K and 2.7K are video modes. Is the question about still photos?
