Calibration
Discussion in 'Standard' started by tdashhoot, Apr 9, 2016.
  1. tdashhoot
    I can't seem to keep an aligned horizon? I end up after completing a leveled calibration straightening out at a plus 1.9. This is really annoying to me. I have a major OCD with how perfect each frame needs to be. It was fine never had any crashes or any reason to cause this annoyance. I own 2 standards and they both are having this problem. Should I update to the newest firmware from this week? Do you think that'll help?
  2. mdowney58
    Mountain City, TN
    You don't have to have OSD to want a level camera.
    Please clarify. Are you saying that it is level after adjusting your camera roll adjustment to +1.9?
    I have no answer as to whether a F/W update will help with this.
    Sent from my SM-N910V using Tapatalk
  3. tdashhoot
    What I'm saying is out of no where It won't stay leveled. I calibrate and it still don't look straight. So I end up having to adjust it too the 1.9
  4. mdowney58
    Mountain City, TN
    There are numerous threads here referring to the "Gimbal Roll Motor Shaft" slipping. Take the rear cover off of the roll motor, and see if the shaft looks correct. There is a flat spot on the shaft that should be level when the camera is level.
    I'm pretty sure the flat side should be at the top, but you'll know when you remove the cover and level the camera.
    If you get your camera level, and the flat spot is a little off, that may be the issue.
  5. tdashhoot
    Ok thanks for the help
Similar Threads - Calibration Forum Date
compass calibration required constantly on screen Pro/Adv Discussion Friday at 3:49 AM
phantom opera esc calibration Phantom 1 Help Jan 9, 2018
Confusion: Compass Calibration CrystalSky Monitors Jan 6, 2018
IMU Calibration ... Phantom 4 Pro Help Dec 28, 2017
IMU Calibration fail.... HELPPPPPP Phantom 4 Help Dec 26, 2017
