I'm sure I should probably know this, but figured I ask... So I haven't calibrated my P2 since August, I think, but haven't flown anywhere within 30 miles of my home anyway. Should I recalibrate just because, or should I not worry about it?
If it wanders a lot when you are hovering, yes and an also do an imu calibration. Otherwise I leave mine alone.
Yep. Started when I put on landing gear extensions. Nothing fancy, just a 3d-printed piece that zip-ties on the bottom of the legs. They fit correctly, was centered on the legs... first time I took off with them on, my P2 didn't even get off the ground, it just tilted backwards and the rear 2 blades hit the ground. Turned off motors, tried again, same thing... turned off, then did a super fast takeoff and it worked. When I was done that day I IMMEDIATELY took off the extensions. When I take off now, it does not tilt backwards, it goes up, but it moves backwards about 5 feet or so. So if you were standing right behind it, it would probably hit you. It is perfectly level when it rises up though. Then when it's in the air, it's perfect. I haven't taken it out in a few weeks because of weather, and I'm concentrating on a quad build. Supposed to be low 60's here in Rhode Island this weekend (for December that's AWESOME!!!), so I'll probably do an IMU calibration anyway.
