C-shaped retaining rings
Discussion in 'Phantom 1 Help' started by KevinOBrien, Sep 26, 2013.
  1. KevinOBrien
    Hi all.
    I'm having problems with the retaining rings at the bottom of the motors. To-date two have come off and one was rattling around loose inside the housing. The other managed to get itself between the motor coils and stuck to the magnets. I can replace the rings even if it is a fiddly job. Should i take it back to the shop and get the motors replaced or just get new c-rings. Has anyone else had similar problems?
    Cheers, Kevin.
  2. Audaciter
    Sunnyvale, California, USA
    They should actually be E-Clips. The thrust washers need to be upgraded as well.
  3. KevinOBrien
    Ok! Thanks for that. Now at least i know what to look for on ebay. Anyone have any idea as to the size they should be? 2 mm?
  4. Audaciter
    You can just search for Phantom motor upgrade parts.
  5. dcoski
    I picked one up at a NAPA store or a auto parts store.
  6. jumanoc
Similar Threads - shaped retaining rings Forum Date
Another New Drone...shaped like a soccer ball! General Discussion Feb 11, 2016
Retaining Control of our Models & Our Privacy - Mike Mas General Discussion Aug 12, 2017
Retaining Go settings/configurations Control (Go, Litchi, etc..) Nov 19, 2016
Gimbal Retaining Pins Zenmuse H3-3D/H4-3D GoPro Gimbal Aug 2, 2014
