Buzzing on startup
Discussion in 'Pro/Adv Discussion' started by tjlt123, Jul 17, 2015.
  1. tjlt123
    Salisbury, UK
    I have just received my P3A. Upon first power up (not motors), there is a loud buzzing noise from the gimbal. Is this normal?
    I had a P2 before but this buzz is much louder.
    Many thanks
  2. acherman
    Alberta, Canada
    Have you removed both the clear plastic guard and the white foam at the back top of the gimbal?
    JBG likes this.
  3. tjlt123
    Salisbury, UK
    Yes
  4. acherman
    Alberta, Canada
    Does the gimbal go through a power up self test and swing all over a couple of times freely? When powered off does it flop around with zero resistance?
  5. tjlt123
    Salisbury, UK
    It works perfectly but there is just a very loud low frequency buzz. I'm about to update it and see if that makes any difference.
  6. robinb
    Its the fan, don't worry about it.
  7. acherman
    Alberta, Canada
    DON'T UPGRADE YOUR FIRMWARE!!!!!!
  8. Robin Slater
    Tamworth
    No mate I have a P3a and have no sound at all from the gimbal other than the twisty start up dance when it initialises. Is the noise constant? Make sure you take the packing and the gimbal clamp off before start up
  9. acherman
    Alberta, Canada
    Sorry , had to get that in quickly. What firmware are you running? Please, before you upgrade, read all of the complaint threads about newer firmware. Don't end up being one of the ones bitching and complaining that firmware broke your aircraft and now you're stuck with something that doesn't fly.
  10. tjlt123
    Salisbury, UK
    I am also unable to connect to the app, it just says disconnected. However I read that I need to be on the a higher firmware to do so. Could I have just been sold a dud?
  11. tjlt123
    Salisbury, UK
    Yeah just a constant buzz.
  12. Waxings
    I had the same issue and it seemed to vibrate enough to cause a video problem. I returned it and my new one is perfect. No issues.
  13. tjlt123
    Salisbury, UK
    Can I just confirm, should it be making any noise at all when idle?
  14. Ken Cruise
    Winston-Salem N.C.
    Archerman have you been waiting for someone to make a post with the word Buzz in it? lol
  15. acherman
    Alberta, Canada
    Haha No, just don't want to see another person upgrade and end up with a pretty paperweight.
    Ken Cruise likes this.
Similar Threads - Buzzing startup Forum Date
Lovely buzzing sound upon startup (with video) Phantom 4 Help Jun 7, 2016
Buzzing around Welwyn... Photos and Video Jun 24, 2017
Gimbal Buzzing loudly and vibrating. Phantom 4 Pro Help Jun 13, 2017
Buzzing?? Phantom 2 Vision + Help Mar 16, 2017
Firmware failure DDDDDD BUZZING SOUND Pro/Adv Discussion Feb 17, 2017
