Built in wifi range ext. Modified it to run externally
I have managed to get the 2.4ghz wifi card in the p3s remote to run externally. All I did was remove it from the remote supply + 4v to the two pins that say 3v3 and ground to the opposite side 2 gnd pins and that's it. I cut up a USB cord and used only the red and black wires too connect to the wifi card. Then I plugged the USB end too a 5v USB charge pack I had laying around and bam! It's working. I'll post the first flight results after I mount it to my 2.4panels then put it on top of my roof and see if it improves the range..any one else out there attempting this
It does work !!!only bug so far is on the remote the light stays solid red.
AdriSmitJnr
