Brown trouser moment, What just hapend?
Discussion in 'General Discussion' started by lukeglazebrook, May 16, 2014.
  1. lukeglazebrook
    I have just completed my second ever Phantom 2 Vision + flight flown RC helicopters for years incidentally. I accidentally few a little too far away and near some Power lines which were round the corner (I wasn't aware of them). The signal was lost and my iPhone said "Phantom returning to base" or words to that effect. I knew this was a feature but what I wasn't aware of was that I would not regain control when back in range?
    I was literally at the mercy of this thing, and being a bit of a control freak felt uneasy. For future reference how can I regain control? I was clearly back in range upon the return flight.
  2. panhygrous pantler
    Reading and understanding the manual before flying your new toy is highly recommended.
    The answer to your question is right there in the manual.
  3. CarlJ
    Peru, Indiana
    I agree that reading the manual will tell you that switching to atti mode will regain control during RTH. :D
  4. Gizmo3000
    Sherman Oaks, CA
    yah,. gotta read up and educate yourself prior to flying a $1,000 device.
    - especially if you plan to fly so far away that you might lose orientation/signal!
  5. FlyingFox
    Cheshire UK
    Toggle right switch down to atti then flick back to gps , as above +1
  6. Phantom_Menace66
    Perth, Western Australia
    When it is close to you again, flick the R/H toggle switch to middle or bottom position and control will be returned to you. As soon as you can see it is now responding to your controller, flick the switch back up to the top position...
  7. evilfurryone
    Estonia
    if I am not mistaken make sure you first turned on the Naza-M mode via software assistant. By default the drone is in Phantom mode, only GPS mode works, no course lock or home lock. After you turned on you Naza-M (and I suggest disabling manual mode by replacing it with failsafe option) you can take over the drone that is returning home.
    I'm saying this because on my first flight ever I tested the RTH option and did not get it to work because of reasons stated above.
  8. QYV
    QYV
    NYC
    quick FYI you don't HAVE to switch to Naza mode and enable IOC just re-gain control in an automatic Failsafe / RTH situation. In Phantom mode (default) the right switch actually does do something: The default setting when toggled down is "normal fly"... essentially re-take control from the autopilot... like, up = normal fly and down = normal fly so if something triggered failsafe (like loss of control with the RC) whenever it could get signal from the remote again if you toggle the right switch you're basically sending the command to re-take manual control from your RC.
    In the Phantom Assistant software (again, talking about Phantom mode only) you can change the right switch function. As mentioned above the default is "normal" but you can set the down position on right toggle to manually trigger failsafe, and re-gain control by toggling back up. I use this feature all the time like an autopilot, when I'm 150-200m up in the air sometimes descending can be a bit boring so I let the autopilot do some of the work for me, then just flip the switch and take control back whenever I feel like it
  9. CarlJ
    Peru, Indiana
    You lazy lump of oatmeal...that's brilliant! I'm flying today and totally doing this! TY!
  10. QYV
    QYV
    NYC
    precisely my reason for utilizing the feature :) it's just plain boring doing a descent from 200m at 2m/s.
    naturally I would verify it's all working as expected at short range before getting aggressive with it. I did both below and above 20m Failsafe tests at a very short distance until I was confident that Failsafe had proper GPS home lock (that it would fly overhead and stop lateral movement) , and that I could regain control at will (by toggling the switches and watching the indicator LEDs.. blinking yellow = failsafe green = normalfly).
    after I was confident, I tested it at long range, the Phantom was at least 2 or 300m away, and high. I triggered failsafe, looked away for a moment and totally lost track of the Phantom, had no idea where it was. I'll admit my pulse raised for a few seconds but then suddenly you hear that sound and look up and it's hovering directly overhead descending.
Similar Threads - Brown trouser moment Forum Date
Brown trouser moment Pro/Adv Discussion Jan 1, 2016
Brown And Black Titles General Discussion Jul 20, 2017
DJIs Phantom Forums policy for brown noses Off Topic Jul 17, 2017
Need info ♦ Hourston Texas ♦ George R Brown convention center General Discussion Mar 10, 2017
Oaks At Windridge | Brownsburg, IN Photos and Video Jan 27, 2017
