Brocken camera
Discussion in 'Pro/Adv Discussion' started by Thebigman, Sep 4, 2016.
  1. Thebigman
    Scotland
    Hi just snapped my camera off phantom s3 advanced is it possible to glue it with anything. It looks like it would glue with something but not sure what type of glue. Also need a new ribbon.
    Thank you for any help.
    Sent from my iPad using PhantomPilots[​IMG][​IMG]
  2. GMack
    Go ask a plastics shop. They sold me some watery stuff in a needle equipped squeeze bottle that welds up plastic. The better shops can tell what plastic it is and what glues to use.
  3. J Dot
    Sarasota, FL. USA!
    Hello
    Sorry to hear it got broken, bummer!
    I personally would search for a replacement arm! This would be your best SAFEST bet, as it would be 100% again, I've seen several of those parts around, pretty common repair! And fairly cheap as well!
    ( this will also insure all your plains ( horizontal, verticle ) will be level and true.( this in my recommendation to you! ) but also my opinion, please do what you want, only advice to you!
    If you are set on mending part
    ( I don't recommend ) as stated before, if it glues out of level or slightly off center, your camera may not level out correctly? ( you might get lucky! )
    Plus if joint fails you stand a chance of loosing a $300 camera, so that $20 part ain't a bad buy!
    If I were to try a repair,
    I would use 2 part epoxy, as the parts are aluminum ( I call it pot metal ) as it is a low grade cast aluminum ( cannot weld or braze it ) epoxy is strong stuff! Most likely does not matter what epoxy you use, as long as it bonds to metal!
    Good luck, and keep us informed!
    Hope this helps!
    J Dot
    :cool:
    dirkclod and Thebigman like this.
  4. Thebigman
    Scotland
    I see a gimble repair arm and ribbon I have ordered. Great advice and thanks. Phantom only a week old, too exited and got carried away. :(. Will keep you updated.
    Reed L and J Dot like this.
  5. J Dot
    Sarasota, FL. USA!
    Good show!
    A+
    You won't be sorry!
    J Dot
    :cool:
    dirkclod likes this.
  6. Thebigman
    Scotland
    Can I still fly the phantom with knackered camera :)
  7. J Dot
    Sarasota, FL. USA!
    I'm not sure?
    I know people fly without them all together but no FPV or telemetry!
    But with the ( damaged ) base of gimbal attached you might get telemetry, but not sure if you'll get a gimbal error or not?
    I'd ask around on that!
    Or hook it up, turn it on see if you get any errors!
    ( some people were taking the cameras off to learn to fly, then replacing them after they were confident of their piloting abilities! )
    But I've never fooled with it on the 3's before, but I know the P2's you can 100% fly with no camera or gimbal!
    I just don't want to give you the wrong advice!
    Maybe post a question about it on p3 board, or there might be an old post about it already? If you would rather search it out!
    Hope this helps
    J Dot
    :cool:
  8. Thebigman
    Scotland
    Ok thanks will have a search but will be cautious safe than sorry. Thank you.
    J Dot likes this.
  9. Reed L
    Alta, Ca.
    Just take of the whole camera from the mount, unplug the cables and your good to go. It flies a lot faster without the camera hooked up and flies just fine :)
    J Dot likes this.
  10. J Dot
    Sarasota, FL. USA!
    A+ Reed L,
    Good show, now we know, Thank you!
    J Dot
    :cool:
  11. Thebigman
    Scotland
    Brilliant thanks a lot. What a great support on this forum.
    J Dot likes this.
  12. Thebigman
    Scotland
    Just noticed a crack on this plate is there a replacement for that?[​IMG]
  13. J Dot
    Sarasota, FL. USA!
    Hello
    Here is a link to one on eBay, kinda pricey though
    https://www.ebay.com/itm/142039754733
    Or call
    Mike Holtz
    ( 530 ) 277-5366
    Great guy, great parts, great price!
    I'm sure he has anything you need!
    Tell him Jerry from Florida sent you!
    As I buy a lot of stuff from him, he might give you a nicer deal, or a good used one cheap!
    Good luck
    J Dot
    :cool:
  14. Thebigman
    Scotland
    Hi wonder if anyone any ideas.. I have rebuilt the gimble with a new ribbon but it is saying gimble not connected. :(
  15. J Dot
    Sarasota, FL. USA!
    Double check that all ribbon connections are correctly inserted fully into their slots, also check wiring closely, as a wire may have pulled loose from connector?
    Next
    Since the top plate was cracked, there is a square circuit on the gimbal mainboard, that can get smashed in a crash, pretty large square component, look over it closely for damage , as well as all connectors on mainboard of gimbal for broken solder joints, or bent pins
    Are you getting any lights on gimbal at startup?
    Lastly
    Can you take some detailed pics of wiring and ribbon, maybe something is a miss?
    J Dot
    :cool:
  16. HYRYSC
    SPRINGFIELD, MO
    Do you guys usually put the camera protector back on when storing your drone or just leave it loose?
    Sent from my SM-T560NU using PhantomPilots mobile app
  17. J Dot
    Sarasota, FL. USA!
    I always use mine,
    When not flying, hope this helps!
    J Dot
    :cool:
  18. John Locke
    Yorba Linda, CA
    That's call a "gimbal lock". Sometimes I use it, sometimes I don't, depending on how far I'm traveling to my flight area, and how I'm traveling. Backpacking, airlines and bicycling to reach my flight area I'll use it. Traveling by car nearby, usually not.
  19. Thebigman
    Scotland
    Ok thanks. Everything looks ok on circuits. I think a slight kink on the cable. Have ordered another just to be sure. I will take photos of everything. The gimble light is flashing red and green. On start up the gimble does move about but the camera part is pointing in various directions. I will put on new cable with photos when I get it and get back.
    Thanks again so far.
  20. GunnyPapa
    Are you shitting me. Seriously this is just such adding insult to injury. If you were serious then think about it, if not piss off
Similar Threads - Brocken camera Forum Date
brocken spectre or fogbow you decide Photos and Video Jan 23, 2017
Lidar Cameras Construction Today at 10:41 AM
P4 camera Classifieds Yesterday at 4:42 PM
Camera/Gimbal not Turing On After Repair Phantom 4 Pro Help Thursday at 2:59 PM
Gimbals Aren't Just for Cameras Off Topic Thursday at 1:57 PM
