boscam ts832 / blackpearl 7" 5.8 issues
Discussion in 'FPV (First Person View)' started by varomedia, Oct 4, 2014.
  1. varomedia
    Hi all,
    I have just got my second phantom which it have used the boscam 832 Tx, with the DJI FPV hub and the mini iOSD.
    My previous Phantom had the DJI AVS58 TX and I could get upto 1km with great reception. This Boscam setup goes to crap at 20m, making it useless.
    I have tried every band and channel and have read about how different channels have different outputs, it is not that.
    I have tried using the DJI cloverleaf antennae off my old set up that got 1km, exactly same result, not that either.
    I had someone else with a screen and RX that gets 1km tune into the same channel as me, his reception crapped out at the same time as mine, thus ruling out my BP monitor.
    Attached is a photo on how it is wired (the order of hub, anti-interference etc), i have tried with the mini Iosd all hanging out the ensure it was interference from the wires inside, that too made no difference.
    One question I had was maybe the fpv hub wasn't giving enough power to the TX?
    Can anyone see something wrong here? Any help appreciated, need to get this thing working ASAP.
    Thanks in advance for your help.
      File size:
      208.6 KB
      332
  2. noiseboy72
    Lincs, UK
    Simple stuff to check first.
    Was the TX new to you? If so, ask the retailer to swap it as it could have a faulty output stage - or is not tuning correctly.
    Have you got the correct connection type between the TX and antenna? There are 2 main types, one with the pin in the "male" side and one with the bin in the "female" side. Running the TX with the wrong - or no antenna could well damage the TX and be the root of your problems.
  3. varomedia
    Yes the drone and tx both bought new from dronefly.
    Yes had already checked and double checked the pins in the antennae plugs.
    Thinking it must be the tx now, hopefully dronefly will swap it for another one... might go back to the avl58
    Thanks for your suggestions
  4. CaptMike
    North Myrtle Beach
    Did you ever power it up without the Antenna on the 832?
  5. varomedia
    No i didn't i am well aware what that would have done.
    After checking absolutely everything, the only conclusion was that is must have been faulty.
    Luckily the guys at Dronefly are awesome and are swapping it for a DJI one.
    Their customer services is fantastic :)
Similar Threads - boscam ts832 blackpearl Forum Date
Boscam FPV 32Ch 5.8G 600mw Wireless AV Transmitter TS832 Reciever RC832 Classifieds Dec 16, 2015
Boscam 600mW TS832 / RC832 FPV (First Person View) Oct 11, 2015
Troubleshooting Boscam RX-LCD5802 / TS832 FPV (First Person View) Mar 6, 2015
Boscam TS832 and Black Pearl FPV (First Person View) Dec 23, 2014
Plug-n-play cable for Phantom 2, IOSD, Boscam TS832? FPV (First Person View) Nov 19, 2014
