Boscam RX-LCD5802 OSD & Aspect Ratio Issues
Discussion in 'Phantom 2 Discussion' started by Mattycee, Feb 6, 2014.
  1. Mattycee
    Hi,
    I am hoping someone can point me in the right direction as my searches have come back empty.
    I am using a Boscam RX-LCD5802 with a 5.8G 500mW TS58500 and I get a decent image but it seems to cut off the sides of the video feed and the Mini IOSD has some of the data cropped off too.
    I am also having an issue with the monitor overlaying its channel and battery level at all times which obscures the IOSD data somewhat.
    Is there a way to make the video feed full screen and also remove the monitors on screen display as well.
    On a side note I get a bit of interference when the Phantom is facing the wrong way over 100m (Is that normal?)
    I appreciate the help and thanks in advance.
    Matt
  2. GhostMaster
    The image loss is normal in the 5.8ghz, 5.8ghz is not good in getting over obstacles
  3. ianwood
    ianwood Taco Wrangler
    Lost Angeles
    There's a setting in the OSD Assistant software to indent the sides if the data is cut off on the screen. As for losing signal when facing the other way, this has to do with the way your antenna is pointing. This is assuming you are using Spironet antennas. If not, you should be. And you should point it straight down so you will be less likely to have an issue facing one direction or the other. And remember 5.8GHz really needs line of sight visibility between TX and RX to work.
  4. Mattycee
    Yeah I changed the settings in the Assistant Software but it did not stay, have redone it and now it is not getting cut off.
    Thanks for that.
    Now I have to try and find out why the image is squished and not full screen and how I can turn off the OSD of the monitor as its on all the time.
    Could the video feed be changed or do I need to change the transmitter? I have seen loads of videos of people using the RX-LCD5802 and it is full screen where as mine has borders on the top and bottom. If I can get rid of these and make the image fullscreen and remove the Monitors on screen display this would be perfect.
    I haven't got Spironet antennas yet but I will do to get better reception.
  5. GhostMaster
    Re: Boscam RX-LCD5802 OSD & Aspect Ratio Issues
    That video tx could go above 2km, TS58500 is the same as TS352 500mw.
    TS58200 is the new version of the TS351, TS58400 is the new version of the TS353.
  6. GhostMaster
    Output power mesured with immersionRC RF meter:
    [​IMG]
  7. Mattycee
    I have not pushed it really, still a bit of a chicken if I am honest, but the highest I have been is about 110m and probably only travelled out the same distance (Though not at the same time as did I mention I am a chicken?)
  8. Godspeedkustoms
    Michigan
    I am having this same issue. Does anyone have a fix to fit the mini iosd data on the monitor? I tried to plug my mini into my computer and make the changes but it does not work for me. Thanks
  9. GhostMaster
    Use the iosd assistant to move the data, yes it works, i made it myself.
  10. Godspeedkustoms
    Michigan
    I have downloaded the iosd assistant and when I plug in the iosd to the USB port it does not seem to recognize it. I open the assistant plug in the USB then power up the phantom radio then the monitor and then the phantom itself to power up the iosd. Am I doing something wrong?
  11. goldfishrock
    Devon, UK
    Have you installed the driver?
    http://www.dji.com/download/phantom-2-downloads/
    Look under 'Assistant Software and Driver' and get the correct one for your Windows version.
  12. Godspeedkustoms
    Michigan
    It's working!!! Thanks guys for all your help. Now I just need to figure out how to get a better picture on the monitor. I have a cloverleaf on the avl58 and just the stock whips on the monitor. Should I change the monitor antennas to cloverleaf also?
  13. d4ddyo
    What EXACTLY did you do to fix this? I am having the SAME ISSUE. there is a LOUD buzzing sound coming from my monitor. How do you turn down the volume?
  14. Pickeringchris
    Old thread, i know. Did you find a way to turn off the osd of the monitor? It pisses me off. makes it impossible to see the voltage from the iosd mini. thx
  15. CaptMike
    North Myrtle Beach
    Also... If the Right side of your screen has interference you'll need to go into your GoPro settings and change from NTSC to PAL. I had to switch to PAL (and I have the Rx-LCD5802). Someone else said they had to switch to NTSC (either way swap).
  16. Pickeringchris
    Lol. Not the answer I was looking for.
  17. CaptMike
    North Myrtle Beach
    Brother, I have Looked through pages and pages of info on the RX-LCD5802 and even found pictures of the circuit board. I was Hoping for some dip switches or jumpers inside to change the PAL/NTSC or/and the OSD... Not a **** Thing. Don't know if you're running the GoPro OSD but when I did the Left Upper corner was stacked with Crap. Phantom voltage is a Must! (Turn your GoPro osd off and it's possible to live with it.)
  18. Pickeringchris
    Yes gp osd is off but still hard to see white voltage overplayed with green crap. Lol. I'm gonna email boscam.
  19. tpimpao
    I have the same issue, the LCD OSD overlay the iosd mini battery signal. Any news from boscam?
    Thanks,
    TP
Similar Threads - Boscam LCD5802 OSD Forum Date
Boscam RX-LCD5802 no video on Diversity mode FPV (First Person View) Sep 17, 2015
Troubleshooting Boscam RX-LCD5802 / TS832 FPV (First Person View) Mar 6, 2015
Boscam RX-LCD5802 charger FPV (First Person View) Feb 3, 2015
QYV, help? Boscam TS352 & LCD5802, FPVLR antennas FPV (First Person View) Nov 28, 2014
DVR for Boscam RX-LCD5802 FPV (First Person View) Nov 8, 2014
