- Joined
- Apr 1, 2016
- Messages
- 203
- Reaction score
- 81
- Age
- 38
Hey all I rigged up a dbs02 which works great, but once I add amps (3 watt sunhans gold) I get problems range is unstable and reduced. It seems I was loosing video link first so I tried swapping amps to make sure one wasent faulty but same problem, I then tried running Radio link amped and video link un-amped at the same time, and same problem. I'm on Litchi at 4mbps. It seems as soon as a single amp is on and transmitting it's skewing both signals is anyone else seeing these problems perhaps these amps are a little overpowered in such close vicinity to the rc and they are picking up and transmitting chatter or causing cross talk. It also seems like I cannot set a channel in litchi no more seems to just revert to what it ever chan it chooses as if in auto.
Does anyone have a successful amped up dbs02 mod on the gl300c using sunhans 3w golds?
The sunhans have a max input of 20dbm the gl300c sticks out 17dbm in CE mode (I am in england) so I can't see me needing an attenuator.
Do you think the sunhans 3w are over powering the dbs02?
I was testing in a highly populated area, do you think I was picking up too much interference pre-amp?
I had the amps stuck to the control surface perhaps this was the problem?
Any input would be appreciated thanks.
