Blinking Lights for the Phantom 2
Discussion in 'General Discussion' started by chess, Jan 10, 2015.
  1. chess
    DMV
    I have looked and maybe I am just blind....
    Just bought a used quad from a guy on the forums... great deal and lots of extras.....
    I went out to calibrate it today seemed to go good with no issues (**** its cold out)
    After I calibrate I get 2 solid red's and 2 blinking greens.... both s1 and s2 are to the very top....
    Any suggestions ?
    Thanks yall
  2. chess
    DMV
    I wanted to add... I had no problem flying it... just my first time out... just curious... thanks guys
  3. Buckaye
    Orlando
    Ummm the two solid reds are in the front correct? That's normal. It's the back lights that provide codes... Red, yellow and green... If they are blinking green you have GPS lock.
    Go to the DJI website and download the manual and read it a few times :)
  4. chess
    DMV
    I've read it a few times lol..lol..
    Ill double check but def 2 reds and 2 blinking greens
  5. chess
    DMV
    Got a lock.... blinking greens and 2 solid reds....
    Took it up probably hell i dont know several hundred feet maybe 100 feet.... got all 4 blinkings reds..... is this due to me being near a military installation ?
    Just curious... was odd it happened....
    Thanks for any help
  6. J.James
    Upstate NY
    if its blinking 2 reds and then greens and back to reds. You are not getting all 7 satellites.
    (if Im remembering right ) One red and then green means 6 satellites
    2 reds then green means 5 satellites ,
    3 reds then greens means 4
    or some thing like that . There is a chart some place that shows the sat count it should be in the manual.
  7. Buckaye
    Orlando
    How long had you been flying? What was your battery level... It could have been a low battery warning
  8. chess
    DMV
    I had 2 solid red's and blinking greens.....
  9. chess
    DMV
    That could have been it.... *shrugs*
  10. MrC
    MrC
    Surrey. UK
    Front should always be solid red when the motors are running.
    Rears should flash green when you have enough sats, or flash red and green if you don't have enough sats. This is a slowish flash.
    The airport zone red flashes are fast flashes - im not sure if all four flash or just the back two. This happens every 5 seconds or so - https://www.youtube.com/watch?v=AlBQFM7LgiA
    Could have been battery. Slow red flash from rear.
    Check restricted areas here - http://www.dji.com/fly-safe/category-mc
  11. chess
    DMV
    GOod stuff... but i am pretty sure the military installation is a no fly zone and i was within 1 mile of that.....
    Its not showing up on the dji link, but i am pretty sure its a no fly ;)
  12. ZeekArmy
    I would'nt be flying a Phantom or any RC Aircraft near any Military Installation...
  13. chess
    DMV
    hovering at 10 ft in the air wont cause anything.... but going up higher I would agree...
    Just find it kind of odd that DJI doesnt have those on the map that is on the website.....
Similar Threads - Blinking Lights Phantom Forum Date
Phantom 4 will not connect ro RC. Blinking yellow lights Phantom 4 Help Jun 19, 2016
Help! Phantom 1 Blinking Yellow Lights Phantom 1 Help Jan 6, 2016
No blinking lights and Red light inside the phantom Phantom 1 Help May 8, 2014
Aircraft disconnected after software update, red RC LED, yellow blinking lights, PLEASE HELP Phantom 4 Pro Help Jul 22, 2017
Red lights blinking when I turn on the remote Phantom 2 Help Jun 20, 2017
