Um if you had watched the DJI videos, which you should now go watch, you'll see that prior to flight they advise you do this to test the motors and listen for any irregularities.Mote
Can you run the motors, with out the propellers on.?.To practice.
Mote
Yes that's the way Simulator is used. Practice to learn stick controls.Mote
You can run the motors with the props off, but I would only recommend you do this if you're testing something that requires the motors to be running for 60 seconds or less. You would not want to let them run for long periods of time on the ground since they will generate a lot of heat and were not really designed to be operated without props attached.Can you run the motors, with out the propellers on.?.To practice.
The motors should be off when running the simulator. I guess that's what you meant, but I just wanted to clarify.Yes that's the way Simulator is used.
These aren't car engines or brushed motors. These are high efficiency low KV brushless outrunners, you can run these motors for hours and hours and they wont get hot unless they are defective.You can run the motors with the props off, but I would only recommend you do this if you're testing something that requires the motors to be running for 60 seconds or less. You would not want to let them run for long periods of time on the ground since they will generate a lot of heat and were not really designed to be operated without props attached.
