Black market vision props
Discussion in 'General Discussion' started by Ozzyguy, Mar 30, 2014.
  1. Ozzyguy
    Townsville,Australia.
    I have the much maligned XXOO 'vision' props on my Ver 1.1.1.
    I get 13 mins flight time with my 2700 and 12 with my 2200Mah.
    Tomorrow I will reattach the original 8inch and update you on flight times.
  2. ElGuano
    Re: Knock off vision props
    I just got and tested genuine DJI NST 9443s against carbon fiber knockoff 9443s:
    viewtopic.php?f=4&t=11153
  3. Ozzyguy
    Hmmm 13 mins on my 2700Mah. I get a lot more speed and vibration with my vision copies. Also a worrying flaring action at the end of a speed run.
  4. Ozzyguy
    Well with the original 8 inch props(or are they8.5?) on I get just over 15 mins with my 2700 MaH. That's using 2500 Ma out of the battery(90% of its capacity.)
  5. Cr8tive_leo
    Ontario, Canada
    Grey market, not black market. I use maytech props, they have the oo stamp, they are just fine.
  6. GearLoose
    ElGuano, has DJI released a plastic 9443 prop for our "legacy", non-self-tightening Phantoms? I fly too close to obstacles to risk the pricier carbon fiber props. If plastic is now available, do you have a vendor link?
    thanks!
  7. ElGuano
    Yes, those are the ones I test in my link above. I got them from 1uas.com: http://1uas.com/DJI-Propeller-9-White-P ... arch=props
    When I went to get the link for you, I noticed the price went down from $15 to $9 a pair! That's an absolute steal, and less than half the price Atlanta Hobby is selling them for. Grab the ones at 1uas.com if you need non-self-tightening plastic 9443s for your Phantom 1.0 or 1.1. I have all the ones I need, and I still grabbed an extra few pairs now to take advantage of the price drop (could be an error and the price may go back up)...
  8. OI Photography
    Clarksville, TN
    Which 2700mAh are you using? And do you know what the voltage was after the flight(s)?
  9. Ozzyguy
    Yes. Down to 10:5 volts
  10. OI Photography
    Clarksville, TN
    After bouncing back for a few minutes? If so, that's a good bit farther than I even push my 2700's, and I'm probably being just a bit too aggressive as it is. Yours might be a little bit better than rated capacity (mine certainly seem to be), but it sounds like you may be pounding them pretty hard.
    If that voltage is right at landing, that's a bit closer to where I draw the line, I usually hit the ground right at 10.6v, and the batt bounces back to 11.1v after ~3 min (and stays there).
  11. Ozzyguy
    That's where my voltage beeper goes off. 3.5 volts per cell. Didn't hit the voltmeter directly after landing(I think it was around 11 volts by the battery beeper). Will do on the next flight aftert he cyclone threat eases.
Similar Threads - Black market vision Forum Date
Professional No stream video, black screen on DJI Go - seems to be related to upgrade Phantom 3 Help Jan 14, 2018
DJI goggles white or black? General Discussion Jan 3, 2018
Standard black magic mod Phantom 3 Help Jan 3, 2018
Black screen of death - me too now ! Phantom 2 Vision + Help Jan 3, 2018
WTS: DJI Phantom 2 w/case and Black Pearl (KumbaCam FPV Kit) $350. Classifieds Dec 31, 2017
