Black goo of death removal
Discussion in 'Phantom 2 Vision + Mods' started by rotorwash, Mar 11, 2015.
  1. rotorwash
    I ordered a spare receiver to see if I could get the black goo off without damaging my bird. I watched Tony's way along with another guy who I would love to give credit to. https://www.youtube.com/watch?v=NPhd0FDsMmo
    Anyways I have a small electric nail grinder for dogs (basically a glorified dremel thats battery operated) I exchanged the sanding drum for a cut-off wheel that was almost used up. Since the wheel was mostly used up it was small and easier to control in tight spots.
    So the nail grinder has a very low speed that works perfectly for tearing into the black goo while keeping control of the grinder. The slower the better. The goo actually comes off with little effort and I was able to get both connectors off in less than 10 minutes.
    The one thing I did that the guy in the video did not was to grind the top of the connecter on the cable side. This gave me a better visual of the goo and an easier/safer way to grind.
    Once all the goo was off, I wiped it with acetone making sure I got everything. I then grabbed some pliers slowly and gently twisted until it moved and popped it straight off.
    I hope this helps others. Time to order my antennas :)
    [​IMG]
    808 Oahu Realtor likes this.
  2. robinb
    Why are you removing glue ?
  3. CityZen
    NYC
    Removing the glue allows unplugging the stock antennas and plugging in higher gain antennas.
  4. robinb
    why is the OP calling it the black glue of death ?
  5. CityZen
    NYC
    The glue is very sturdy. Several people have managed to break their receivers while trying to remove it.
  6. saltire
    There was a guy on here who was selling the boards with the antenna's already removed.I have always thought about doing this mod as i think you will get better reception than doing the solder job on the original antenna's.
    Very very important to use good glue when fitting new antenna's as you dont want them coming loose which = no control signal thats why Dji use good quality cement .
    #6 saltire, Apr 5, 2015
  7. 808 Oahu Realtor
    Just Orderd a board off amazon with the wires removed. Much worth my time and head ache.
    I will follow up to let you all know how it works.
    Is a hot glue gun best to fit the new wires, to make sure they do not come off in flight?
  8. CityZen
    NYC
    That's what I would use.
  9. saltire
    You got a link to the Amazon ones .
  10. 808 Oahu Realtor
    Ok so update on the one on Amazon which says the wires are off. IS BS!!! I was so Pissed.
    I got the part and its has wires. So back to the drawing board and try to get them off.
  11. Forts
    But there is no epoxy.... So just unplug the wires? I don't really see the problem....
  12. 808 Oahu Realtor
    There is a Black epoxy which is HELL to get off. But I got a dermal and used a sand paper wheel to get it off. Result done!!!
    I have two other boards coming, I will do a video and post.
  13. jasonnelson007
    I failed..... where can I buy a new receiver? How about one without the cables..
  14. 808 Oahu Realtor
    I would be willing to sell the two I have coming. Let me know
  15. jasonnelson007
    Do they have the cables removed?
  16. jasonnelson007
    I would be interested. When do you expect them and how much?
  17. jasonnelson007
    Sent you a PM.
  18. 808 Oahu Realtor
    Cool, I should have them before the end of the week. I can then take the wires off and could send to you. I can place it on Amazon or ebay for you to buy would $75 work?
  19. hunch
    i have a bunch as i remove the black cement on a daily basis on these.
    here is a link i created just for one side how i do it.
  20. jasonnelson007
    Ya that's the method I used. It didn't work for me. 1 good and 1 not so good.
Similar Threads - Black goo death Forum Date
1st attempt black goop of death Phantom 2 Vision + Discussion Mar 8, 2015
FAIL: Black goo of death (epoxy) Phantom 2 Vision + Mods Oct 20, 2014
Any good black friday deals? General Discussion Nov 17, 2017
The Good, The Bad & the Ugly: State Farm, A Crash & The Black Hole Known as DJI Service General Discussion May 23, 2017
Did anyone find any good Black Friday deals? Pro/Adv Discussion Nov 25, 2016
