Bit Rate differences
Hi there,
I see one other not too publicized difference between the adv and pro units is the 40mbs/60mbs bitrate, in practical terms what difference does this make? Is it only an issue at 2.7k and above?
Thanks,
R
actually the 60mbs is for the 2.7 and last I heard was 30mbs for the 4K but it's in bits per second or mbps is megabits per second. The higher the number the faster, sooo... If you want to run some video in slow motion, the faster bit rate to begin with will give you a smoother slow motion video. It's one of the main reasons that I bought the advanced over the pro because I do a lot of slow motion clips in my videos.
reed L, I think you are confusing bitrate with frame rate.
For slowmo, 60fps is ideal because you can export to 30fps, 50% speed, with zero quality loss. Bitrates are irrelevant.
Higher bitrates will have more detail captured in the video. Analogous to jpg versus raw in stills....more bits, more details, sharper video especially if there is fast motion in the image.
DUH... I like to look dumb sometimes :confused: Yup frames per second... Anyway the P3A has the 2.7K/ 60fps where the pro doesn't or didn't offer 60fps when I bought my advanced
Hi there,
Thanks,
R
As of the latest 1.5.3 version of firmware, the bitrate of P3A has been increased to equal of P3P's 60Mbps when recording in 1080p/60fps mode.
P3A's 1080p/30fps mode has its bitrate increased from 25Mbps to 40Mbps in this latest firmware too.
Ahmmm no, P3A does not record in 2.7K/60fps. 2.7K is limited to 30fps.
In the latest firmware, P3P also offers 2.7K/30fps mode.
Reactions: skyhighdiver
Where did you see this detail? I don't recall seeing it in the release notes.
Do you suppose this new F/W increases the image quality when using the HDMI port with goggles? That's what many folks complained about with the slower bitrate of the P3A.
@Noodle - If you are knowledgeable enough, would you mind making corrections to this old table I copied from somewhere a while ago?
UHD
4096x2160 @ 24fps - 60mbps
3840x2160 @ 24fps - 60mbps
3840x2160 @ 30fps - 60mbps
2704x1520 @ 30fps - 40mbps
2704x1520 @ 24fps - 40mbps
FHD
1920x1080 @ 60fps - 40mbps
1920x1080 @ 48fps - 40mbps
1920x1080 @ 30fps - 25mbps
1920x1080 @ 24fps - 25mbps
HD
1280x720 @ 60fps - 20mbps
1280x720 @ 48fps - 16mbps
1280x720 @ 30fps - 10mbps
1280x720 @ 24fps - 8mbps
Sorry Oso, all I can confirm is the two modes I have flown in so far:
1920x1080 @ 60fps - 60Mbps
1920x1080 @ 30fps - 40Mbps
Thanks sir.
Hi there,
Thanks,
R
Actually 60mbs for 4K is a pretty low bit rate if you compare it against 4K (or UHD, which is 3820x2160) on prosumer camcorders that support UHD between 100mbs - 150mbs. However, 60mps would be good enough for most prosumers. Yes, it's not all about bit rate but it's something worth considering if your mixing rushes on your timeline and pushing your grading.. Though grading 4:2:0 colour spaced material is limiting too.
Well there have been a few complaints that 60Mbps for 4k in GoPro Hero 4 Black is a bit low too. So this is not new for P3P. Sony action cam has about 100Mbps for their 4k video.
cokersean20
