If you keep the transmitter OFF and connect the battery to the Phantom (with props removed) you will see the red light inside the battery compartment. That indicates that there is no signal being received. If your controller is already bound the light will go off when you turn on the controller. If it is not bound the light will stay on. To bind a new controller, push the little button next to the light while the controller is off and the light will turn yellow/orange. Then turn on the controller. The light will go off, indicating that it is bound.
Check this indoors with the props off. You will see the light.
