Can anyone please tell me 1:if I may need to post this elsewhere as I'm new here and 2: what's the biggest battery I can possibly fit in the phantom battery compartment?
gbshovel said:The 2700 mad dog fits but if your going to jam the wires inside you will run into issues sooner or later.
I just filed a couple cutouts on the body and door so I can connect from the outside.
ElGuano said:JTheed, nice to see another dual mad dog user. What voltages do you run down to? Conservatively I can get 18+ min on 5400mah, pushing it I can get 21+.
ElGuano said:Jtheed-the 5400 is two maddogs combined into one battery.
Djidan, those are great results, what are your voltages set to for alarm and auto-land?
djidan said:ElGuano said:Jtheed-the 5400 is two maddogs combined into one battery.
They have not been adjusted, therefore they will be what ever the defaults are. I think I could possibly lower these to give me even more flight time, but don't want to damage my batteries.
havasuphoto said:Very good points. I've noticed when I pull out my single maddog 2700 mah, that the exit voltage is about .10th lower than a standard battery. Normally, a DJI 2200mah will come out at 11.25 or so...while the MD will come out at 11.15.
I never wait for the 2nd level, always landing at 1st level. My Phantom is a pig-and trying to land it with 2nd level warning, on my "heli-tub" is just too difficult.
When I see 10.9 volts-loaded, on my iOSD-it's time to take the Goggles off, and the Phantom is always right in front of me. I use a time on my remote to remind me.
Also-I write in a log every flight-all my batteries are numbered(I think I have 14 or 15 now-including 5 maddogs). I write down the voltage in/out, and after 5 minutes(or when I finish the next flight), I record the voltage of the battery...I'd like to see at least .10 volts returning.
Also, I monitor the difference between the 3 cells. I think someone mentioned no more than .70 of a volt between the 3? Anymore than that, and it might be time for a replacement?
havasuphoto said:gbshovel said:The 2700 mad dog fits but if your going to jam the wires inside you will run into issues sooner or later.
Wondering if you had some side pictures of where you did your cut-outs? Also, couldn't you just file open some spots on each side of the battery door itself?
