Opwan said:Say your up pretty high and you want to come down quickly, what's the best and safest way to do it?
wkf94025 said:I agree with Chuddly that the corkscrew down is a good technique in tight quarters. My instincts are that straight-ahead descents are safer, and I sometimes slide forward and backward while descending. However the corkscrew is helpful at times. Also, by playing with amount of forward right stick during the corkscrew, and/or amount of yaw, I can do non-circular descents that bring me closer to home while bleeding altitude (i.e., tigher turns when facing away from home, more open turns when within 90 degrees of straight home).
Re Jebus' question, in my experience it depends substantially on your All Up Weight. If you're flying heavy, I would be cautious about the corkscrew or descent rates greater than 0.8m/sec. Unless you find VRS fun, which I do but only at altitude.
Kelly
wkf94025 said:Try adding 200g somewhere on your P1, and I think you'll have some exciting descents at those rates!
varmint said:What he said. If you go straight down with too little lateral or longitudinal velocity, you can introduce vortex ring state which can potentially ruin your day. DJI attempted to address this by capping the maximum vertical decent rate at 2M per second in the last firmware update, but even that can be too fast depending on conditions. Personally I'd rather make my own caps, and I have no idea why they didn't just set that as the default rate and allow you to modify it (within reason) via the assistant.
Anyway, just make sure you're moving horizontally (relative to the air mass) when you descend. Wind alone will not protect you, since the unstable air you create under your pops is moving WITH you if you unless you have your own velocity.
Opwan said:You will! If you keep descending straight down!Jebus said:My Phantom v1.1.1 weighs in at around 1200g and I usually descend around 2m/s (sometimes I notice I'm going quicker - more like 3m/s) and haven't had any issues - even coming straight down at those speeds. I can't say for sure what speeds I've reached descending while going forward, but I'll have to watch for that now. Luckily I haven't had to deal with VRS yet!
Wedeliver said:I went looking but I could not find a thread where I think it said that DJI was releasing new props to help with the issue you speak of above. It was maybe a 1 week ago but I searched and I just don't remember what the subject was where this was mentioned. I think we all have an interest in this especially if we like to fly loaded.
