Best suspension kit for OSMO ? (anti-shake)
What kits are you guys using to remove or reduce the slight camera shake you get when walking with the OSMO ?
I have to say that it works a treat and shake is minor but just wondered if there was anything other than the z-axis that maybe worked better ?
Personally I have found that the Z-axis does not eliminate the up and down movement enough for me. The best solution in my opinion is to walk like a ninja and shoot everything in 1080p 60 fps and have your shutter speed set at 120. Also invest in a variable ND filter so you can always have the shutter speed at 120.
Here is a travel video I shot using these settings. All Osmo and Phantom 4 Pro, expect for a couple of shots on my DSLR unstablized.
most
