Best location for FPV Antenna for Long Range. T-Connector?
Discussion in 'Phantom 2 Discussion' started by jfischer, Apr 30, 2014.
  1. jfischer
    So last night i received by Fatshark Patch Antenna in the mail which I promptly tested out. My ranged increased to 1.5km+. I got to about 1600 meters before turning back.
    I knew when I turned back I would probably lose video reception, and of course I did. Currently my fatshark spironet v2 antenna is mounted pointing down, but I think the the fact that it is behind the gimble isn't helping the line of sight at 1600 meters. I was wondering where people mount their FPV antenna's to get longer ranger. I know you can almost mount it anywhere and get 500-800 meters, but I am looking to the people going out 1.5km+ and have good reception no matter what direction the phantom is facing.
    I'm was also wondering if anyone has ever tried or thought of using a 'T-SMA' connector to mount two antennas to a FPV transmitter. One pointed in each direction to help avoid LOS on things like the gimbal.
    Thoughts?
    [​IMG]
  2. gasato
    Re: Best location for FPV Antenna for Long Range. T-Connecto
    Just mount the antenna sideways (choose the opposite side to the compass), so it won't be covered by the Gimbal on the coming back. Something like this: (2trickpony's setup) [​IMG]
  3. jfischer
    I was thinking of mounting with the transmitter facing back but using a T to get an antennas pointed out each side. That way no matter what way it faces, an antenna would be in LOS. Anyone try that?
  4. jondrew
    Here's my setup. I have a 90 deg connector that let's me point the spironet straight down. I bought the extended legs on eBay. Immersion 600mw Tx. I have the patch on my receiver and have gotten 2km so far. Probably would have been good out to at least 2.5km but my battery was hitting 50%
    [​IMG]
    [​IMG]
  5. damoncooper
    Boston, MA
    Can I ask what cable and patch antenna holder you are using and where you got them?
    Thx!
  6. badbrad97
    I have almost the same set up and I am wondering with the two channel Boscam receiver, does it use both antennas?
  7. jondrew
    I think so. "Diversity" monitors use both antennas for input and display the strongest signal
  8. 2trickpony
    Aberdeenshire, Scotland
    I would give the T connector a try and see how you get on.
  9. tom3holer
    Cape Cod, Ma.
    DO NOT USE THE T connector for the transmitter. The transmitter is designed to operate on a certain impedance and could hurt the Vtx if you add two antennas in parallel which is what the "T" will do.
    Tom
Similar Threads - Best location FPV Forum Date
Best location to place Strobon strobes to P4 Pro? Phantom 4 Pro Discussion Apr 8, 2017
P2, Immersion RC 600mw, IOSDmini Install Location (Whats Best?) Phantom 2 Discussion Apr 18, 2015
Best Location on P2 Go Pro version for GPS Locator General Discussion Feb 8, 2014
Best firmware for P3A? Pro/Adv Discussion Friday at 4:18 PM
Advanced Best style settings ? Phantom 3 Help Tuesday at 2:09 PM
