  1. CardiacKid
    Phoenix
    What is the best case you all can recommend for the P4? Are the backpack style protective enough? Look at holding the drone, 2 batteries, iPad mini and a cover for the iPad when it's too sunny.
  2. Big Al KY
    I have a Microraptor case which is great. I also have the backpack as well. The foam interchanges with each other.
    Stores alot of stuff here like 5 batteries, remote, 9.7 iPad and 8 props and more. Check it out, it is the best out there:)
    Mike_Flys likes this.
  3. Alex Baxter
    County Kilkenny, Ireland
  4. Mike_Flys
    Box Elder SD
    I agree with Alex. It depends what you want to use it for.
    I like the big hard plastic suitcase for the great protection. But I have been eyeing backpacks so it will be easier to carry while hiking into places, especially since the only thing my wife likes better than hiking is dragging me along.
    Amazon has a great selection.
    Here is what I currently offer in cases. Remember if you order anything from me to use coupon code PHANTOM to get the forum discount.
    You might want to check Carolina Dronz as well.
  5. msinger
    Approved Vendor
    Harrisburg, PA (US)
    CardiacKid, you can find a list of commonly used Phantom 4 cases and backpacks here.
    There really is no best cases/backpack. I like the Go Professional and Microraptor Pro hard cases (I own both). And, many people like the Drone Trekker backpack. Backpacks obviously don't have as hard of an exterior, but many offer enough protection for most usual flying activities.
    Geeno likes this.
  6. ChrisW
    Alex. Are you saying that the anbee one is good? I thought it might be an example of what is not but the reviews on Amazon seem favourable despite noting it feels cheap. Thanks C
  7. JAAir
    Wales, UK
    Here's a vid for the Anbee showing how the guy packs in his Phantom.
  8. craigsdal
    Check out the ProCraft Backpack especially if you have several batteries and accessories. A little big but very protective for all traveling.
  9. Bill Golson
    Grant Park, GA
    If you want a hard case and don't mind doing the cutouts this is an affordable choice:
    Plano Molding Large Weatherproof Pistol Case - 18.4in x14.25in x8in -- comes with solid thick foam. About $60. I bought two for my P3s/P4. Will upload pix if interested. Case closed.
  10. Geeno
    Personally, I invested in the Go Professional Compact case. Its dimensions are under the carryon limits. Its really solid, and i like the density of its foam. Remember, your protecting a $1400 piece of machinery. If the intent is to protect it, I wouldnt skimp out on a solid case. Unless you have deep pockets to always buy a new on like Casey Neistat. Haha
  11. Geeno
    How do you like the microraptor case compared to the go professional. Are the foam inserts of similar quality and durability? I was debating between the 2 and was considering the microraptor cause it has a backpack bundle. In the end, i went with the Go professional since it had lifetime warranty and was located in my hometown.
  12. Bckmstr
    MN
    Just received my compact hard case by case club for my p4 and could not be happier for the protection it will provide
  13. Bckmstr
    MN
    everything you listed you want it to hold mine does and more room...bought it off amazon for $129 had the bigger skb one but took it back as it didn't fit the p4 well at all...very disappointing as i have a skb for my bow and it's top notch for that
  14. Barry Peterson
    I just got the LowePro Drone guard backpack.......really badass! super high quality, fits EVERYTHING with room for more. I have 4 batteries and a boosted remote......plus harness etc.....still not full..
    amazon
    maseman88 likes this.
  15. Bill Golson
    Grant Park, GA
    Hey Geeno -- $60 bought this case -- weather proof -- plenty of latches -- rigid and ribbed -- comfy handle.
    I'd have to say it provides the same protection as a $200 plus Pro case. Put that savings to other P4 stuff like more batteries. etc.
  16. MK47
    San Diego, CA
    Got a link?
  17. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Both are great cases. The foam in the Go Professional case is slightly more dense. I have no complaints about the foam in the Microraptor Pro case though. Both cases are built very well.
  18. John Locke
    Yorba Linda, CA
    I have the Microraptor hard case, it's a first class product. I keep my P3P #2 in it since it allows storage with props installed. This gets me in the air quick, I use it for commercial work. It gives me the professional look in my clients eyes, which is important since Phantoms look like toys. I was going to buy their backpack that uses the same custom insert, but it's not small enough for carry-on for airlines. That's important to me, so I use a ProCraft for my P3P #1 when traveling, and my P4 gets a ThinkTank Helipak backpack since I like it best.
    If you're not doing commercial work, I think you'll find that using a soft backpack is the way to go. It's more convenient, lighter, and doesn't beat up the car as much, loading and unloading, versus a hard case. The best part is taking your Phantom on vacation, backpacks generally fit in the overhead carry-on for airline travel, and when you get there you can go backpacking with it. You definitely don't want a hard case for traveling. There are a dozen backpacks out there for P4, I've bought 4 of them, and sent some back. Good luck with that selection. I recommend buying it with Amazon for easy returns in case you don't like what you bought.
  19. Alex Baxter
    Hi ChrisW, It's a very good case for the price, I had a couple of issues with poor stitching, which the wife (a drone widow) repaired in a few minutes. I'll have no issues taking it on an aircraft as hand baggage (but I would watch nervously as other people put their stuff in the overhead locker beside it), then trekking around the Pyrenees with it. There's room for all your phantom stuff, water and sandwiches too, without it being some ostentatious giant beer cooler box that shouts 'drone'. It takes a bit of time to sort out the interior partitions, but persevere, and it'll all become clear.
  20. Bill Golson
    Grant Park, GA
Similar Threads - Best cases Forum Date
Best cases for Phantom 3 Pro/Adv Discussion Apr 12, 2016
Best/All Cases for phantom with gear Phantom 2 Discussion Nov 13, 2015
Where is the best place to buy drone only? Phantom 4 Discussion Yesterday at 7:18 PM
Best firmware for P3A? Pro/Adv Discussion Friday at 4:18 PM
Advanced Best style settings ? Phantom 3 Help Aug 15, 2017
