Bent props? Motors?
Are these blades suppose to be atleast level? See fist pic is then I Rotate the blade then took another picture and one side is higher then the other .
Also see the motor? It appears to be on and angle, the grey piece. Must be normal they all seem to be the same .
The motors are canted slightly to increase stability and also to aid start movement when you want to fly in a direction.
The angle is by design.
Nigel
Reactions: AllDubyas and Vzr1
jrl
