Just curious, has anyone here experienced this issue? Don't know if something is lose inside, but I tap the bottom top portion of the remote and it stops...Please I need some help, its driving me nuts!
Have you done any software upgrades? Dropped the controller? Recalibrate it?
I have heard of this happening on the P2V+... usually a recalibration fixed them.
The part about hitting it and it stops makes me think like you, there is a problem that needs to be addressed with DJI.
Not sure I would have enough confidence in the remote to use it. Well, lets see what happens after a calibration.
Glad to hear it worked out! I recently got all set to fly and for some reason the props would not start... back in to hook it up to the assistant. Calibrated it and it worked fine. If I run into a weird issue, I hook it up and take a look.
I see you already have the answer. That happened to the one I just bought with an antenna mod installed. A remote controller calibration fixed it up. Don't forget the gimbal wheel too!
