My phantom 2 battery isn't charging. I double clicked the on button just like you would to check the cells in the battery and now when I plug the battery in it won't charge. HELP!!!!!
Put it back into the P2 and check battery level in the software. Does the chargers green LED come on when it's plugged in and does turn red when the battery is connected to it??
I'm having the exact same problem. The charger light is green when it's plugged in even though it's not charging. I have another battery working fine it's just this one with the problem. Any ideas folks ??
