Is it fair to assume that the VOLTAGE reading of batteries (in my case, a P3A) is more accurate than the PERCENTAGE reading of a battery - which I assume is supposed to reflect the CAPACITY of the battery?
Should we monitor battery voltage primarily and use the percentage reading (capacity reading, I am assuming) as a secondary guide?
Does the software monitor the VOLTAGE of a battery and then try and deduce what the remaining capacity is, since there is a ROUGH correlation between voltage and remaining capacity??? I know that a lot of battery monitors work this way since it is easier to monitor voltage accurately than it is to measure capacity.
Or has DJI actually developed an accurate way to monitor remaining CAPACITY?
And if I am correct and we really should be monitoring VOLTAGE first and capacity second (again, assuming that the PERCENTAGE is referring to the estimated remaining capacity of the batteries), at what voltage level (in a stable hover) should we start landing?
Thanks in advance.
Thanks in advance.
