Battery voltage crashes answers
Discussion in 'Pro/Adv Discussion' started by Wibble, Dec 24, 2015.
  1. Wibble
    Brecon Beacons Wales UK
    Ok so after much reading is the following an accurate summing up?
    1. Voltage drops below a certain figure then it just shuts off to prevent damage to the cells resulting in a crash.
    2. Sudden acceleration on a low battery can cause a momentary voltage drop. Again leading to a crash
    3. Cold weather will make the problem worse.
    4. New update limits power to prevent this happening
    IF all the above are true wouldn't it be better for DJI to over ride battery shut off?
  2. N017RW
    Palm Beach Co.- FL
    Voltage sag, regardless of cause, drops below regulation drop-out value.
    (This may be a confluence of many factors.)
    Imbedded uP resets in flight.
    Flight control lost.
    Gravity does what gravity does.
  3. tcope
    Salt Lake City, UT
    So far it appears that this is only an issue with the P3 and it appears to only be a real issue when the batteries are cold. The best answer is to correct the issue and still allow the battery to turn off when it's critically low. DJI thinks that they have done this.
  4. RedHotPoker
    Edmonton Alberta
    They know what's best for your drone. & We don't know.
    I live in a cold country, so Definately looking forward to this cold flight battery update. ;-)
    RedHotPoker
  5. msinger
    Approved Vendor
    Harrisburg, PA (US)
    True, but how would DJI educate people to stop flying it like they stole it when the battery voltage is low? It might make the best sense to configure the Phantom to control the throttle when needed, but have a setting that would allow that throttling to be turned off. Kind of like manual mode in the P2V+.
  6. tcope
    Salt Lake City, UT
    I don't think my post was 100% clear. My remark is that I don't know DJI doing anything else is a better solution. I think what they did (if it works correctly) is the best of both worlds.
    Also, we don't know for sure what all was changed. I would agree that another change that should be made is to not allow the battery to turn off if the drone is reporting a home point... or something along those lines. I'm ruling out the motors being on and its possible someone would be running the motors to drain the battery and, for example, not have the props on. There should be several ways to do this. But as I mentioned, I don't know for sure that they did not make this change.
  7. msinger
    Approved Vendor
    Harrisburg, PA (US)
    It seems odd that it's shutting off and not getting to the critical low battery stage first. Perhaps the voltage drop is so drastic that it doesn't have time to kick in.
  8. kphantom
    I agree, it would be better for DJI to do something different. Why would they allow a battery to shut off while in flight? This does not make sense.
  9. tcope
    Salt Lake City, UT
    I think it's been shown that it does get to this critical state. Under cold temps and full throttle it was. So the batteries shut off. This is why DJI has now limited full throttle when the batteries are cooler.
    I know that I'll still be flying for a bit before getting anywhere near full throttle. Having your P3 fall 40' onto pavement will have this affect.
  10. msinger
    Approved Vendor
    Harrisburg, PA (US)
    Per the Phantom manual, at the critical low battery level, the Phantom is supposed to auto land itself. It seems that function is being completely bypassed sometimes.
    dirtybum likes this.
  11. tcope
    Salt Lake City, UT
    Two different measurements. Critical is being used to describe many things. Critical battery when it comes to flying is around 20% or near 3.2v. Critical when it comes to a killed battery might be closer to 2% or 2.xv.
  12. msinger
    Approved Vendor
    Harrisburg, PA (US)
    I'm only referring to the "critical low" battery level -- as described in the Phantom manual. Critical in general could translate into a vast array of things.
Similar Threads - Battery voltage crashes Forum Date
Is my battery toast? Lower voltage on 1 cell Pro/Adv Discussion May 8, 2017
How fast will battery voltage drop if Phantom is just idle Pro/Adv Discussion Feb 13, 2017
Battery voltage 3.69 Pro/Adv Discussion Feb 12, 2017
Battery voltage drops a bit fast Pro/Adv Discussion Feb 9, 2017
Battery voltage problem General Discussion Dec 17, 2016
