Professional Battery taking 20hrs to charge
Discussion in 'Phantom 3 Help' started by Ckin, Mar 27, 2016.
  1. Ckin
    I'm new to the p3 pro world. For some reason my DJI batterys are talking all night to charge. The battery's have only been charged 9-11 times and show 100% health. I am using the DJI 100w charger. When unit was new the battery's charged in about an hr. I have tried to take one batt down to the 8% but that does not help. I have also tried charging with power on. Still no good. All lights flashing like they should. Please help.
  2. Sinisalo
    try a new outlet to plug into or try a new charger, process of elimination. It wouldn't be the batteries unless both were faulty at the same time which is not likely
  3. Ckin
    wow thanks for the prompt reply. I have tried a different outlet. No diff. I guess I will go and buy a new charger and try. I bought this unit brand new and have only flown it about 12 times
  4. mdowney58
    Mountain City, TN
    You haven't said, but are you by chance charging more than one battery at the same time?
    Sent from my SM-N910V using Tapatalk
  5. Ckin
    No I am only charging 1 batt at a time. Nor am I trying to charge the RC at the same time. I just measured the output voltage of the charger and it reads 17.2vdc which according to the label on the charger should be correct. Oh and this happens with both of my battery's.
  6. mdowney58
    Mountain City, TN
    Was that output voltage measurement taken while under the load of a battery connected to it?
  7. Ckin
    no the 17vdc was with no load. When charging the battery I measured (just now) the voltage using the free RC connection it read 15.2vdc.
  8. garykeithmead1
    Uk
    Does it charge th r/c ok ?.
  9. PEEFA
    You need to check amps drawn from charger while charging the battery. I would say the charger is goosed sorry sir
  10. Ckin
    Thanks everybody. I broke down and bought a new DJI 100w charger today. Everything works just as it should. So it was a bad charger :(.
Similar Threads - Battery taking 20hrs Forum Date
Taking Care of my Battery Standard Dec 31, 2017
The Pros and Cons of taking a Dji Battery to the 8% level to balance cells Phantom SE Dec 17, 2017
Is taking-off with a 95% battery (let's say a few days after charging) safe enough or should we rech Pro/Adv Discussion Nov 13, 2016
Phantom 4 battery taking 6-7 hours to charge Phantom 4 Help Oct 9, 2016
Taking Off With Less Than 100% Battery? Pro/Adv Discussion Sep 25, 2016
