Battery Stress Test?
Discussion in 'Phantom 2 Vision + Discussion' started by JakeMaxxUAV, Mar 14, 2015.
  1. JakeMaxxUAV
    Approved Vendor
    Does anyone know of any stress tests to see the health of the battery?
  2. Meta4
    Meta4 Moderator
    Staff Member
    Have you seen the battery display in the Assistant software?
  3. JakeMaxxUAV
    Approved Vendor
    Yes I have, but I was thinking of something that put it through some tests to see how it reacted under heavy load.
  4. Monte55
    Raymore Missouri
    If you had a accurate scale the Phantom could sit on would be good. Measure the weigh of Phantom. Fix the quad to scale platform. Fire up Phantom until it is lifting the Phantom weight and see how long the battery will last. I have a digital scale so it's easy for me to do.
  5. N017RW
    Palm Beach Co.- FL
  6. Dirty Bird
    Glen Burnie, MD - USA
    That was a very informative video. If you watch the entire video, near the end he shows the effect of temperature on the battery performance. The change from 76 degrees to 36 degrees is startling with internal resistance tripling! Goes a long way in explaining why batteries give premature low-voltage warnings under heavy load in cold weather.
  7. JakeMaxxUAV
    Approved Vendor
    Yes it was, thanks for the share N017RW!
  8. N017RW
    Palm Beach Co.- FL
    My pleasure gents.
    It's the least I can do to 'give back' here!
    Edit: typo
  9. happydays
    Warrenpoint, Ireland
    Good information. Would there be any issues rigging up a similar test bed using the smart batteries? Would the electronics in the cap affect the test? EE is not my strong point!
  10. yorlik
    Very interesting idea! So if you throttle up till scale reads 0, that is lifting its weight, or equiv lift/work of level hovering.....
    Going to negative drone's weight means it is equiv of accelerating up with 2G.
    I am VERY interested in knowing what full throttle lift capability of the phantom vision 2+ ver 3 is: what is max pounds you can get? what is max you can sustain?
  11. Monte55
    Raymore Missouri
    Since my scale is digital, I can zero it at any time. The platon is about 12 inch square. I can put the quad on, tie it down...zero it ...give full throttle and see how much it will lift. You won't be picking up pounds
  12. yorlik
    The accuracy of this spreadsheet is very dependent on the state of charge (SOC) at the time of the test; you will find results vary ---amount may not be right over 3-4x - but it does vary -- depending on SOC. Unless I missed something, it should clearly state that the battery MUST be fresh off a 100% charge before using the results.
    As example, I could watch my lipo full EV car bat resistance change this amount depending on charge, and that with one of the worlds most advanced BMS systems.
    Otherwise, this is a great spreadsheet! internal resistance is a great indicator of battery health.
Similar Threads - Battery Stress Test Forum Date
P4 remote and battery stress cracks Phantom 4 Discussion Jul 10, 2017
Battery Stress Cracks? Phantom 4 Discussion May 4, 2017
Over-stressing the gimbal/ND Filter/Battery/Flight Question Pro/Adv Discussion Dec 21, 2015
New Battery Won't Charge General Discussion Today at 1:35 PM
P3 battery problem and motor overload Standard Yesterday at 10:20 PM
