Battery Settings in the assist software
Discussion in 'Phantom 2 Vision + Discussion' started by Cnash, May 20, 2014.
  1. Cnash
    Has anyone changed their battery percentage in the assist software?
  2. xgeek
    London, UK, Declination -1.2
  3. Cnash
    What is a safe percentage you can set you battery to in the assist software?
  4. chriske
    I set the first warning around 25% and the second one at 15%.
  5. pyrophantom
    Somerset, UK
    Thats what my stock settings are anyway ??
  6. supertrooper
    Can anyone tell me when they rush back home during a flight? 25%? 20%? 15%? Just wondering how far you guys push it. I fly over water so I always head back when it hits 25%.
  7. 4wd
    4wd
    North York Moors
    If you change the final warning setting, does that start the phantom's emergency descent routine sooner or later?
    Or is that governed by reducing voltage it detects itself. :?:
  8. EMCSQUAR
    N 44.895 W 93.354 Minnesota
    That depends on where you set it. The "auto descent" is triggered when it hits the 2nd battery warning level.
  9. xgeek
    Auto-landing also triggers when the battery hits 10.65v. This can happen even before you reach 30% if your battery has a weak cell and you push the Phantom hard and draw too much current.
    Section 6.5 Low Battery Capacity Warning Function
    Code:
    (3) There is a hidden third low battery threshold in addition to the 1st and 2nd level warnings. This uses 10.65V as its threshold. Both this voltage threshold and the 2nd Level Low Battery Warning will trigger auto-landing. Altitude can be maintained if necessary by pushing up on the throttle stick.
  10. Mal_PV2_Ireland
    Dublin Ireland
    To maintain battery life dji have always said not to fly below 20% and to completely drain the batteries after every 20 full flights.
Similar Threads - Battery Settings assist Forum Date
Need Help Understanding Assist. Battery Settings General Discussion May 1, 2014
"Failed to reset password. Please try again" in battery settings Phantom 4 Pro Help May 13, 2017
P3S Acft battery menu, advcd settings, details,status, "Self-Discharge in storage" msg help Standard/4k Discussion Jan 31, 2017
P4 preferred low battery settings General Discussion Oct 30, 2016
Battery Settings Phantom 4 Help Oct 22, 2016
