battery problem
hello
i have a problem with phantom 2 battery
when i put the battery in the aircraft and try to turn it on
the battery green leds start as unseal but then the red led on the and the aircraft doesn't turn on
battery stays on and that it the battery stock in that position
for about 5 minute it Does not matter what you press
the phantom is ok with another battery
hope you can help me
It is a pleasure to welcome you to the Phantom Pilots forum Sharon. I hope that you will take advantage of the benefits that come with membership and that you will be able to use the forum for the exchange of innovative ideas and as a resource for current developments in Phantom quadcopter’s.
Have you looked at the battery status in the assistant software? Start there if you haven't done so already. ;)
I cant turn on the aircaraft so i cant connect
To the software
Here is a video of the problem:
The first one is good battery
The second one is the bad one
Sent from my SM-N920C using Tapatalk
shimuafeni fredrik
