Battery not charging/No charging indicator lights
Discussion in 'Phantom 2 Vision Discussion' started by fireye81, Jan 20, 2014.
  1. fireye81
    Hi all,
    I have just fired up my PV2 after a couple of weeks of no use, I updated the camera firmware and thought i'd charge up my batteries but when I plug them in I get nothing on the battery, no lights at all. My charger is seemingly working, it has it's green indicator light on and when I test for voltage accross it's charging pins I get a constant 12.71v. I have 2 PV2 batteries and it is the same for both! I have tried wiggling connections but not the hint of a charging indicator!
    I can't believe both batteries have just decided to stop taking charge at exactly the same time for no reason. if I plug the PV2 in to the assistant software with each battery, all outputs, battery life % etc seem fine.
    Has anyone else experienced anything similar? Any things to try? Can anyone confirm 12.7V ccross the charging pins to ensure this is correct?
    Many thanks in advance
  2. Pull_Up
    South Oxfordshire, UK
    Try plugging the battery in to the charger and then "switching the battery on" as you would to fire up the Vision. If you do that it will hopefully start the charging flash sequence for you...
  3. fireye81
    Thanks a lot Pull up, that does seem to have got it going!
    It's strange though as I certainly haven't had to do that before and I have charged all the batteries several times!
    Fingers crossed it shall continue to charge and discharge normally.
  4. Pull_Up
    How long exactly did you leave them since last use, and what charge level were they left at?
  5. fireye81
    Both batteries were last used on the 6th January, I left them stored in my case at room temp, one at 40% charge the other at 47%.
    I have read that with the Vision this should be about right but feel free to let me know if i'm wrong, as i'm still learning the dark arts of Lipo usage and storage at the moment!!
  6. djayz
    If the batteries were almost full and you tried to 'top them up" then that behavior you saw appears to be normal. Mine does the same thing if I try to charge a almost full battery.
    You need to drain a little power from it first then it will start charging. It must be some sort of safety feature.
  7. Pull_Up
    So am I :lol: , but what you did is pretty much ideal, and it's not that much of a lay-up. Maybe it's just that the smart circuitry needed a kick up the proverbials to get things going. Probably worth having a look at both batteries in the Assistant again once they have been fully charged just to make sure no cells are doing anything odd, etc.
Similar Threads - Battery charging charging Forum Date
DJI BATTERY LED1 FLASHES 3X , not charging Standard/4k Discussion Yesterday at 5:23 PM
10% Battery Doesn't Start Charging Pro/Adv Discussion Yesterday at 8:16 AM
Battery Charging General Discussion Jul 19, 2017
Battery charging hub question Pro/Adv Discussion Jul 17, 2017
Cooling down a battery before recharging Standard/4k Discussion Jul 13, 2017
