I am planning to install soon fpvlr antenna. My limitation is now the battery. Anybody tried battery mod, and can you share the details??
That type of battery needs the white plugs which are used for balancing when charging.Looks interesting. How to fix the cable on the original battery. And what is the purpose of the white plugs from the 2 small batteries ?
Yes I have the Hyperion 1800 mah 166 grams this is a high volt battery.each cell can be charged to 4.35 volts giving you 10% more fly time same as Dji battery.can not test it to see what kind of flight time I can get do to -20 temperatures.i have done my own battery mod same as fpv.customs or fpv horizon does the same mod but alittle different.fly safe...aircraft.world is where I got my batteries and banggood is where I bought my charger the dual balance charger/ discharged D100 Sky RC power 2x100 very good charger....
A lot of money to be made in all the fluff,flora,fauna.big bizzz this hobby.So I just need to buy some wire and 2 connectors which fit my extra batteries and then solder? That sounds way to easy.... Why do these modded batteries sell for hundreds?
Also do you know if dji can check the p3p flight log and void warranty if they see an aftermarket battery used?
Could a battery mod be done with one of this type high aHA battery.
V1 High Capacity 12000mAh Emergency Car Jump Starter Battery Power Source with Three USB Charging Port
Why don't dji use this tech for their batts anyway, they are lightweight and high power output.
